Hydronic Baseboard Not Working Properly - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 09:39 PM   #16
JohnH1's Avatar
Originally Posted by Massed615 View Post
copper fin baseboard fed by pex on the first floor the second floor is a heat pump fed by pex and that work great
Heat pump I assume water to air? This is being feed from the boiler also?
JohnH1 is offline   Reply With Quote
Old 01-14-2009, 09:44 PM   #17
JohnH1's Avatar
Originally Posted by buletbob View Post
dont want to but heads on this post, but I would say the system was choked by the 1/2 Pex. going from 3/4" to 1/2" on the first floor I would have to say your choking the zone. BOB.
1/2" can feed 3/4 baseboard but only so much of it. We dont know if a single loop or how many feet of baseboard the loop has on it yet. Sooo may things still to determon and almost bed time for this old man
Old 01-14-2009, 09:48 PM   #18
JohnH1's Avatar
Do you mean a air handler with a hot water coil or actually a heat pump?
Old 01-15-2009, 05:30 AM   #19
An old Tradesmen
Rewards Points: 7,288
" pex, doesn't have the same flow rates at the same head pressure as " copper.
You probably have a Taco 007 or equivilent circulator.
Its probably too small for the GPM you need.
You need someone to come out, and check the head the circulator is working against. And to check temp rise through the boiler.
Old 01-15-2009, 02:42 PM   #20
sorry for some reason I didn't see the other posts. My best guess is the second floor which also has AC has 5/8 pex runn up to the attic which heats a coil and a fan that blows the hot air to each room. This system work great its very responsive and it holds a constant temp. The down stair is 1/2 in pex fed to about 40' of base board on a single loop
Massed615 is offline   Reply With Quote
Old 01-15-2009, 08:55 PM   #21
And that is a separate zone on the boiler
Old 01-15-2009, 09:09 PM   #22
would a circulator pump help? If so what kind of horse power should i get if it running about 100' total including the 40' of base board
Old 01-15-2009, 09:11 PM   #23
JohnH1's Avatar
Not enough pipe for that much baseboard. Read this http://www.bellgossett.com/Press/Cou...arch1995-A.pdf
Old 01-15-2009, 09:22 PM   #24
Thanks after reading that it looks like I could have a couple of causes:
1. where 2 ends of half inch pex meet who ever installed it you 1/2'' copper to connect them this happens a couple of times on the loop
2. My loop might be too long and i could be losing pressure and temp by the last room. if this is the case is it possible to run two loops off the same zone?
3.The " pex is too small
Thanks for the input I have a plumber coming out on sat hopefully I don't have to replace all the pex
Old 01-16-2009, 03:46 PM   #25
Tags
bleeding boiler , heating problems , laars endurance
baseboard heater not working bobcatnj Plumbing 6 10-30-2008 09:21 PM
Hydronic baseboard brand name Joe F HVAC 3 02-05-2008 07:50 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
