Old 01-14-2009, 10:02 PM   #1
Question Hydronic baseboard not working properly
I just bought a house and the bank I bought it from hired a plumber to install a boiler. I had some say in the matter but was ultimately advised to go with a Laars Endurance due to some direct venting issues. I had no problems with the boiler until it started getting cold out (below45). Once that started happening I noticed the base board wasn't putting out much heat, I can set the thermostat to 90 degrees and the room one get above 54 on a bad day and 63 on a good day. There has been an occasion or two when the temperature has reached 68-70 so the system is capable of heating the area its just most of the time it doesn't. I called the company that installed it(who I don't trust farther than I can throw them) and they told me that the pex feeding the base board was too small, ½ opposed to 3/4, and that I needed more base board. But I was told that Half inch pex has the same flow as 3/4 copper because there are no fittings and like I said the system can Heat the whole area at times so I don't think I need more baseboard. I have a digital thermostat and which I have programed and reset and reprogrammed to make sure that wasn't the issue. My next thought ist to bleed the system but I'm not quite sure how to do that. Any suggestions? sorry the post is so long
Massed615 is offline   Reply With Quote
Old 01-14-2009, 10:23 PM   #2
JohnH1's Avatar
Man were to start. I could be sooo many things. 1st 1/2 pex is not the same as 3/4 copper. Has it heated to normal temp when it was cold out or only when the weather was mild.
JohnH1 is offline   Reply With Quote
Old 01-14-2009, 10:29 PM   #3
When it was cold out
Old 01-14-2009, 10:33 PM   #4
JohnH1's Avatar
Next when it dosent heat enough does the burner cycle off or continue to operate.
Old 01-14-2009, 10:36 PM   #5
continues to work as long as the digital thermostat is set above the current temp. My gas bill was$180 last month
Old 01-14-2009, 10:40 PM   #6
JohnH1's Avatar
If it continues to operate then it is giving up all the heat the boiler is putting out. Check that the boiler is firing at full rate.
Old 01-14-2009, 10:42 PM   #7
You'll have to bare with me I have no HVAC experience what soever. What I do know is that the digital read out for the tank temp 190 degrees and my hot water works extremely well
Old 01-14-2009, 11:00 PM   #8
JohnH1's Avatar
Hopfully the 190 is the boiler water temp and not the domestic water. If you are delivering 190 deg water to the heating system and the burner dosent shut off then it sounds as if the boiler is to small except for the fact you say it has heated durring the same cold weather otherwise. Maby others can think of somethin els.
Old 01-14-2009, 11:03 PM   #9
no my domestic is set around 140-150, i have no small children and i think my wife is smart enough not to put her hand in scalding hot water
Old 01-14-2009, 11:06 PM   #10
Please excuse my mis use of terminology but I read some where that the heat exchange can get clogged with air?
Old 01-14-2009, 11:10 PM   #11
JohnH1's Avatar
Nah if is was air bound it would be cycling on high limit. Are you sure the burner (fire not pump) continues to run when the house is cold and not able to keep up.
Old 01-14-2009, 11:16 PM   #12
The burner only runs when the tank temp drops to 150-160 then it fires it up to 190 and shuts off
Old 01-14-2009, 11:26 PM   #13
JohnH1's Avatar
Ok so the burner does cycle off when the house dosent maintain temp. This says it is not the boiler itself. what type of heat emitters are in the house. Copper tube baseboard?
Old 01-14-2009, 11:27 PM   #14
copper fin baseboard fed by pex on the first floor the second floor is a heat pump fed by pex and that work great
Old 01-14-2009, 11:35 PM   #15
BUILDER / REMODELING CONT
buletbob's Avatar
dont want to but heads on this post, but I would say the system was choked by the 1/2 Pex. going from 3/4" to 1/2" on the first floor I would have to say your choking the zone. BOB.
Tags
bleeding boiler, heating problems, laars endurance
More On This Topic
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Hi, I'm Terri Turco with Expert Village and I'm going to tell you about the two separate ways to melt chocolate. In the first method what you do is you melt chocolate over, what they call a double boiler. Well obviously, it's just a pan and what you do... Read More »
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Hey guys my name is J and I'm talking to you today on behalf of Expert Village. On this clip I'm going to show you how to heat a double boiler. Right now I've got my pan on high heat. What I'm going to do is get about four cups of water and you want to... Read More »
hydronic hot water baseboard justorr Plumbing 0 12-02-2008 08:36 PM
baseboard heater not working bobcatnj Plumbing 6 10-30-2008 11:21 PM
Hydronic baseboard pipe sizing Joe F Plumbing 0 10-01-2008 12:09 PM
Hydronic baseboard brand name Joe F HVAC 3 02-05-2008 09:50 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 07:47 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
