I think I reset all the breakers, but I will attempt again to be sure. Tried flipping the override switch and nothing happened, but maybe I didn't leave it switched long enough. Water level looks fine, but will take a closer look to be sure. I think its an analog control.
We also have a heat pump. Had both the indoor and outdoor heat pump units replaced last fall and everything worked as expected last winter and up until a few days ago this winter. I guess the Hydrokientix part of the system wasn't serviced at that time. They kind of tried to talk me into getting rid of the Hydrokientix. What type of service do these need? The HVAC company I've used is familiar with these (so they say), but they never recommended any kind of service.
Thanks.
Originally Posted by beenthere
Did you try resetting all breakers inside the panel/control box on the hydro?
Did you setting it to over ride?
Have you checked its water level(too low it won't activate the heaters)?
Is your an analog or digital control?
When is the last time it was serviced?
