HVAC Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 08:06 PM   #1
Question
HVAC won't shut off
Ok....first off I know very little about HVAC. I have a heat pump out side (Tempstar 5000) Same brand air handler inside. System should be about 10 yrs old. When i set the A/c to 74......sometimes, not all the time, it wont shut off and i'll come home to a VERY cold house. Same thing happens with the heat, I set it for 68 and come home sometimes and it's like 90! I have a digital thermostat about 6 yrs old and i can hear it "click" when the temp is hit but nothing happens. I usually have to shut off and on the breaker a couple times to get it to shut off. Again doesn't happen often but enough to be annoying and waste of money!
Any ideas?
Sling Blade is offline   Reply With Quote
Old 05-25-2009, 09:41 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,434
Sounds like a bad thermostat. I would replace it with a Honeywell Vision or Focus Pro type. Make sure you get one suitable for a heat pump and CAREFULLY label the wiring and follow all the wiring instructions or call a pro. If it runs too long the compressor can get damaged from a low load/coil freeze up.
Old 05-25-2009, 11:10 PM   #3
You need one of these
hvaclover is offline   Reply With Quote
Old 05-26-2009, 05:28 AM   #4
Question
So i'm not sure exactly what model the thermo is but it's a 7 day program digital Honeywell......was already installed when we bought the house. So even though I hear the "click" it could still be a bad thermostat?.....if so i may just go buy a cheapie to test it out......I had assumed that not hearing the click would indicate a bad thermostat.........but you know what they say about assuming!
Also, I know the indoor blower is suppose to run for a bit after the outdoor unit shuts off but every since we have been in the house the blower stays on 99% of the time?........I can even turn the system off...(when it cooperates) and the blower stays on.....
Old 05-26-2009, 08:29 PM   #5
Hvac Pro
yuri's Avatar
Could be a bad tstat with a short in the subbase and that can cause the fan to be on also.
Old 05-26-2009, 10:29 PM   #6
HVAC / Plumbing
I like that... Do they come in digital models ??
kenmac is offline   Reply With Quote
Old 05-27-2009, 08:41 AM   #7
That has digits,, 50 - 60 -70-ect.
Old 05-27-2009, 01:07 PM   #8
HVAC / Plumbing
Ok,Ok.. I like the rustic designer look
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
HVAC Upgrade Questions JonC HVAC 8 02-27-2009 06:04 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
