HVAC Wiring Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 09:33 AM   #1
HVAC wiring question
I am trying to learn more about how the HVAC system in my house is wired together. I have a two story home with one furnace that is hooked up with a zoned system (2 zones) using a honeywell hz311 zone panel.
On the zone panel there is a section for equipment that has 6 connections that can be made: Rh Rc W Y G DS/BK
Correct if I am wrong but the meanings for each of these connections are:
Rh - This wire comes from the 24VAC transformer on the heating system.
Rc - This wire comes from the 24VAC transformer on the air-conditioning system.
W - This wire comes from the relay that turns on the heating system.
Y - This wire comes from the relay that turns on the cooling system.
G - This wire comes from the relay that turns on the fan.
DS/BK - not sure what this one does.
So on my panel in the equipment section, the only connections used are Rh, Y, and G. I am confused why there is no connection to the W connector. If this is the suppose to go to the relay that turns the heating system on then i would think it would be utilized. I've included a picture of part of the zone panel.
http://s655.beta.photobucket.com/use...81dc0.jpg.html
vertex78 is offline   Reply With Quote
Old 01-25-2013, 11:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,588
Ayuh,... You'll get more, 'n Better answers if ya say, Exactly what yer Hvac system consists of...
Hot Air furnace,..??
Hot Water Boiler,..??
The Zone thing makes me ask the question....
Old 01-25-2013, 02:36 PM   #3
I have an Amana Gas Furnace model# GCI115x35A, and an Amana ac unit, not sure the model number of that. But if needed I can look it up. There is a thermostat upstairs and one downstairs. There are 2 zones in this setup with 1 damper on each zone.
Old 01-25-2013, 02:50 PM   #4
Roofmaster
Rewards Points: 2,210
OK Guys, How ya do dat???? I thought 2 zones require 2 units???
Old 01-25-2013, 02:53 PM   #5
The duct work coming out of the unit is split into to legs, and in each leg is a dampers.
Old 01-25-2013, 07:17 PM   #6
An old Tradesmen
Rewards Points: 7,730
Looks like they may have bypass the equipment W and went directly to the stats W. Can tell for sure, pic too small.
Old 01-26-2013, 08:23 AM   #7
I looked at the panel again and none of the w terminals on any of the stats are being utilized. Here are some close ups of all of the connections on the panel
http://s655.beta.photobucket.com/use...5193c.jpg.html
Old 01-26-2013, 10:36 AM   #8
An old Tradesmen
Looks like they bypassed the panel on the W connections. may be a problem with the panel. Or they don't know how to configure the panel correctly.
Old 01-26-2013, 11:19 AM   #9
I think the wiring is all janky on this system. The homeowner whom i bought the house from wire it all and I dont think he knew what he was doing. I am working on drawing up a wiring diagram to show how everything is connected. I will post it on here when I am done with it.
Old 01-26-2013, 02:22 PM   #10
ok so i have mapped everything out and here is how the system is wired.
http://s655.beta.photobucket.com/use...79fac.png.html
Old 01-26-2013, 03:32 PM   #11
An old Tradesmen
Pic is too small. But it shows a lot of bypass wiring.
Low Voltage Wiring Question.. scyarch Electrical 3 10-23-2011 11:00 AM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
HVAC and Joist Blocking Question bassprokd HVAC 3 02-25-2010 05:42 AM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
