HVAC Will Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 08:37 PM   #1
HVAC Will not turn on
Hi
I have a 10+ yr AC that will not turn on.
The thermostat clicks but then nothing. The unit i has a Honeywell ST9120 G4004 fan controller.
I disconnected the thermostat and on the fan controller when I connect the
R+Y = cooling starts
R+W = Heat starts
R+G = Fan starts
I do not know whether the Thermostat or the Fan controller is broke. Ideas/thoughts anyone?
grasshopah is offline   Reply With Quote
Old 06-02-2010, 09:59 PM   #2
Your tests confirm the funace,blower and AC work without the thermostat so the problem is the thermostat or a thermostat wire. Hook the controler back up then twist the wires at the stat to see which it is.
Old 06-03-2010, 08:15 PM   #3
Thanks for the reply.
It turned out that there was drip pan switch connected in series. For some reason the switch was "open" even though the pan was bone dry.
Removed the drip pan switch from the circuit and the AC blows coool!
Have to look around for a drip pan switch now
Old 06-03-2010, 10:06 PM   #4
Rewards Points: 85
HUH?
If that is the case when you jumped r-y nothing should have happend.
Oh well maybe the cooling you were talking about was just the blower coming on.
mikethe ductman is offline   Reply With Quote
Old 06-04-2010, 04:48 AM   #5
An old Tradesmen
Rewards Points: 7,414
Originally Posted by mikethe ductman View Post
HUH?
If he jumped R to Y directly at the control board in the furnace/air handler. that would bypass the wet switch. If the wet switch is wired to the R or Y from stat to board.
Old 06-04-2010, 05:49 AM   #6
Rewards Points: 85
Oh ok I thought he took the t-stat off and jumped r-y
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 04:06 PM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
