HVAC/water Baseboard Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 08:54 PM   #1
HVAC/water baseboard heat
I have hot water baseboard heat. There was no heat on the first floor. I blead all coin vents. Managed to get heat in 2 of the four rooms. Can't seem to get anymore air out the two cold rooms. Not sure what to do now.
Tp54bigt is offline   Reply With Quote
Old 12-12-2010, 09:03 PM   #2
HVAC / Plumbing
Trapped air can be hard to get out sometimes. Try to keep bleeding. How did air get into the system? Do you have auto air bleeds ?
kenmac is offline   Reply With Quote
Old 12-13-2010, 04:43 AM   #3
An old Tradesmen
Rewards Points: 6,824
On the ones that aren't heating. Did you bleed until you got water out. or did they stop leaving air out and you still had no water coming out.
Old 12-13-2010, 12:53 PM   #4
Thanks for the help. All of the finn tubes had air in them. I bled them all and only two of the 4 have hot water coming out the others just cold water sprays out. I guess I'll try bleedind some more, after that No Clue.
Old 12-13-2010, 12:58 PM   #5
Thanks for the help. After bledding all? the Air out, they all spray water 2 are hot and 2 are cold. I guess continue bleeding, dont know what else to do?
Old 12-13-2010, 05:21 PM   #6
An old Tradesmen
There may be air pockets in the piping. You may have to purge the pipes.
Post pics of the piping at the boiler.
Old 12-13-2010, 06:27 PM   #7
What is the best way to purge the pipes. I have drained the return line at the boiler.
Old 12-13-2010, 06:28 PM   #8
Send pict of set up
Hixheat1 is offline   Reply With Quote
Old 12-13-2010, 06:53 PM   #9
Not able to send picture at this time
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
heat not circulating to baseboard needhelp56 HVAC 8 02-28-2010 06:05 PM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 11:17 AM
electric baseboard heat drewhart Electrical 21 11-05-2009 08:12 PM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 04:04 AM
