Old 01-31-2009, 12:27 PM   #1
Question HVAC & Washer Dryer: Shared space problem?
I have a condo in a hundred-year-old building & the Builder put the HVAC (open draw near open vent to the hallway) in the same small closet as the Washer-Dryer hookups.
A recent inspection by a Air Cleanliness expert told me that this design is bad, even dangerous, and possibly against code. While I don't have a W/D right now, he said the open draw HVAC will suck up all chemicals (bleach, soap) & dust and push them through the HVAC unit and into the condo.
Further, the dampness & heat from the W/D will damage the unit & force it to work much harder than it should (for instance, in the summer, when i'm trying to dry clothing & cool the condo).
Of course I'm upset, if the Builder should have known better. Or is this guy nuts?
Any thoughts?
KnoxCondo is offline   Reply With Quote
Old 01-31-2009, 12:39 PM   #2
hvaclover's Avatar
It would harm the furnace internals, yes.
Bur unless there is actually an opening to the cold air return then nothing can get pulled in the heated air that warms your home.
Besides...the amount of aspiration the cleaning agent cause is negligible,
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-31-2009, 01:33 PM   #3
old pro
By "open draw" do you mean the return air to the unit is not connected to ductwork and just into the condo with a grill? I recommend people keep their fabric softeners etc in a sealed plastic Rubbermaid container and that prevents the flame sensor and internals from fumes etc. The W/D have to go SOMEWHERE and yes they give off heat. Unless you like going to a laundromat you will have to have them there. I would buy some high end units that have the front loading. Apparently they use a lot less water, wring most of the water out, and require less drying and gives less wrinkles. Worth the extra $$ and will keep the heat load down. There are some hydro/utility rebates $$ where I am for these units as they are more environmentally friendly, check it out.
Old 01-31-2009, 01:42 PM   #4
An old Tradesmen
As Yuri said.
Keep cleaners and softners in a container that is air tight.
As far as the humidity hurting.
Where would that humidity go if the furnace return wasn't there.
Into the rest of your condo, so it would still have to work the same amount.
All house hould Cleaning/bleaching, softning chemicals will do more harm then humidity will.
Tags
air, dryer, hvac, vent, washer
More On This Topic
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
Many are lucky enough to have a washer and dryer in their home, but there are plenty of situations in which one might find themselves dependent upon a public laundromat in order to clean their clothes. The washing and drying process is somewhat different... Read More »
Relocation of washer and dryer genie Plumbing 2 01-25-2009 04:29 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 07:07 PM
Space around the HVAC unit? QueenL HVAC 8 04-16-2008 02:50 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Gas HVAC Clearance/Open Space Q? snowbro80 HVAC 5 12-13-2006 08:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
