HVAC Very Weak Upstairs With Zone Control Installed - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 05:21 PM   #1
Angry
HVAC very weak upstairs with zone control installed
I've done a bit of research and still can't find a solution. Our AC system blows fairly strong and cold downstairs but barely blows at all upstairs. The house is a little over 3 years old, and approx. 1350 sq. feet. There is an Aprilaire zone control system in the attic wired to the 2 thermostats (I'm assuming) and the air handler and a wire running to a duct coming from the air handler that runs to a large box with several runs of ducting coming out of it. My guess is there are dampers in the ducting that should be controlled by the zone control system, but nothing I've done seems to change anything. I've reset the zone system and also tried turning off the downstairs thermostat to no avail. The AC unit is on almost continuously, but still blows very little out of the upstairs vents. I'm fairly handy, but don't know much about HVAC units. I also don't want to call someone and have to spend the $$. Help, it's flippin hot!
g8rben is offline   Reply With Quote
Old 06-14-2009, 05:37 PM   #2
An old Tradesmen
Rewards Points: 6,098
Good chance the second floor ducts are undersized.
Or, the second floor damper isn't opening the whole way.
Old 06-14-2009, 05:54 PM   #3
The ducts seem to be fairly good size. It's not a very big house and the ducts appear to be in the 18-24in range. My guess is the dampers aren't opening, but they seem to be controlled by the zone control system without an obvious "manual override." Is there a way to manually open them or get them "unstuck?"
Old 06-14-2009, 07:34 PM   #4
An old Tradesmen
Some have a manual lever on them.
The main may be 18", but what size are the supplies goping to the rooms.
Old 06-14-2009, 07:40 PM   #5
The ducts to the rooms can't be smaller than 12". If there isn't a manual lever, is there any other way to disengage them and leave them open?
Old 06-14-2009, 07:51 PM   #6
An old Tradesmen
If they are flex ducts. The outside diameter, isn't the size of the duct.
Some don't have a manual overide.
In that case, other then removing them, no way to overide.
Check your warranty. Might have a 5 year warranty on the dampers.
PS: If you overide the dampers for the second floor. Then the second floor will get heat or cooling when ever the first floor calls.
adding 3rd zone to honeywell trol-a-temp system bhelman HVAC 5 03-03-2010 05:11 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 05:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 01:02 PM
HVAC Upstairs QUESTION Statecowboy HVAC 1 09-15-2007 12:15 PM
