HVAC Unit Not Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 09:25 PM   #1
Unhappy
HVAC unit not heating
Hi there. My wife and I just purchased our first house back in May and I'm not too familiar with HVAC units but we're having some issues with ours that I've been looking for some help on.
Our home has four floors and dual zone air. The upstairs bedroom area is ran on one with the unit in the attic and heat pump outside. When it gets really cold, or just lately here in Maryland, the unit does nothing but blow cold air out no matter what. I've tried to use the emergency heat and it does not work either. I only let the emergency heat run for maybe 20 minutes, you can smell it but it still blows cold air out. We've got it set to 65 and it will drop down to high 40s, maybe 50s at night. If I turn the heat all of the way up to 90 degrees, it gets a big warmer but nothing too significant.
When we turn the heat on, the heat pump will turn on for a few minutes but cut off shortly after, and kick on once in awhile but the fan still stays on constantly. We have had some electrical problems (power randomly going out for a few seconds then back on) but I have checked the breaker box in the basement and there appears to be nothing switched 'off.'
I believe the heat pump is a Gibson, and the thermostat is a White-Rodgers. Before we moved in, the previous owners installed all new units so there should not be any issues with age.
Could it be a faulty thermostat or something with the heat pump? We do have baseboard heat throughout the top 2 floors but I am a bit hesitant on using that with the costs as I'm trying to keep my electrical bill as low as possible.
Thanks in advance!
Lace
Lace is offline   Reply With Quote
Old 01-03-2010, 09:33 PM   #2
Could be the low pressure switch on the heat pump. Probably worth the $ to have someone check it out. If it's new I'd call the company that installed it and hopefully they won't charge you.
hvac benny is offline   Reply With Quote
Old 01-03-2010, 09:39 PM   #3
Only problem is I have no idea who installed it But it's looking like I will have to have someone come out soon. Cant continue sleeping with it being that cold up here. At least we've got a heated mattress pad
If it matters, it's all electric.
Old 01-03-2010, 09:47 PM   #4
Try the previous owners, or their real estate agent, or your real estate agent. You may have to dig a bit, or you may have to pay someone.
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
Heating Unit in the Attic Bad Idea? Part of House on Slab cloves HVAC 3 08-18-2009 11:37 AM
Why is water coming out from the bottom of the HVAC unit? Woz HVAC 11 08-02-2009 08:38 AM
Heating Unit farooq Plumbing 2 07-18-2008 05:23 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
