HVAC Unit Leaking Water - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 11:00 PM   #1
My central air unit has been leaking water for a few weeks. The tech. came and vacuumed out water and added some tablets to clear the algae. It seemed to help for a few hours. Now, there's water leaking again from the main unit. I just checked the pipe by dumping water & bleach from the unit to the drain in my 2nd floor and that seems like a good flow. However, I'm still getting an overflow drip into from the unit into my yard.
Does anyone know what could be causing the unit to leak? I don't think there's a clogged pipe since the water flowed well from the unit to the 2nd floor. Thanks!
timb10594 is offline   Reply With Quote
Old 08-26-2009, 09:51 AM   #2
HVAC / Plumbing
coil pan cracked,, rusted out ??
kenmac is offline   Reply With Quote
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 10:07 AM
Kent water meter leaking fjgap Plumbing 2 05-29-2009 09:48 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
