Hvac Trips Breaker - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 09:11 PM   #1
Rewards Points: 258
Hvac trips breaker
Okay just has a new load center installed. The breakers are all new so I know they arnt a problem. But I think the problem was happening before anyway. So the problem is the circut breaker trips when the ac unit turns on.
redman88 is offline   Reply With Quote
Old 10-11-2012, 09:16 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
There's a short somewhere.
Did this happen before the nee panel was installed?
If not,I'd be looking at the panel.
sublime2 is offline   Reply With Quote
Old 10-11-2012, 09:52 PM   #3
Rewards Points: 258
i do belive it was happening before, i did not look to close at the previous subpanel for the AC, the new breaker is in the new load center.
Old 10-12-2012, 08:58 AM   #4
Rewards Points: 380
What size of breaker is going to your unit and what is the rated amp draw of the unit?
HVACDave is offline   Reply With Quote
Old 10-12-2012, 10:26 AM   #5
Rewards Points: 258
60 amp and I don't know the rated
Old 10-12-2012, 05:39 PM   #6
An old Tradesmen
Rewards Points: 6,580
Data label on unit will have the amp rating.
Old 10-12-2012, 06:24 PM   #7
funfool's Avatar
Rewards Points: 534
I really have no useful info, but I do wonder what unit you have and if it has a separate motor between heat and ac?
Does heat side work and only ac side it trips breaker?
As I stated, I have no real info to help, but if you post the make and model of your unit, would be good way of getting useful info to ask more questions and others help you.
funfool is offline   Reply With Quote
Old 10-12-2012, 08:33 PM   #8
Rewards Points: 258
Haven't tried the heat side did get on the roof and looked at the data plate it's a 70 amp ac. After see the pull disconnect on the unit I kind of remember seeing one by the main fused/leaver disconnect on the house. But I only looked one real quick. So a trip to the hardware store tomorrow hopfuly the local store has one so I don't have to drive 50 miles one way to get it
Old 10-13-2012, 06:59 PM   #9
Rewards Points: 258
Well the electrician came back over and put his amp meter on the leads going into the ac it spikes up to 170 amps for a few seconds the the beaker trips. He thinks its the capacitor. The top bulges a little
Old 10-13-2012, 07:14 PM   #10
An old Tradesmen
May be the capacitor. Their cheap, so try a new one.
The Following User Says Thank You to beenthere For This Useful Post:
redman88 (10-13-2012)
Old 10-13-2012, 09:07 PM   #11
Rewards Points: 258
Where do I go to get one
Old 10-13-2012, 09:55 PM   #12
An old Tradesmen
Grainger. or any electric motor shop.
Old 10-13-2012, 10:46 PM   #13
Rewards Points: 258
Found that the original has a new part number and found it on amazon ordered and on the way
Old 10-17-2012, 09:00 PM   #14
Rewards Points: 258
Received and replace the capacitor, problem fixed. AC up and running
Old 10-17-2012, 10:48 PM   #15
An old Tradesmen
Good, glad it was a simple fix.
Garage Heater Trips Breaker Pacodeveux Electrical 7 12-12-2011 10:41 PM
How to test that a breaker trips on short BradSG Electrical 13 07-08-2010 09:45 AM
20 Amp Breaker only trips once in a while panhandlion Electrical 14 11-26-2007 09:36 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
breaker trips when too much is used lightone Electrical 11 04-29-2007 11:20 PM
