HVAC Trane XE70 Motor Swap - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 11:23 AM   #1
HVAC Trane XE70 motor swap
Hello,
I have a Trane XE 70 furnace with AC. The blower motor went out so I bought generic motor. I installed it already. I think I need to increase the speed as in the air flow at resisters is low. Can someone help me figure this out?
Do I run this in Med.-Hi? or low Med.?
First picture is coming from the new motor. I splice the old connector on.
Second picture is to the furnace
Third picture is old motor
Fourth picture is the new motor.
I did this last fall. Furnace heated the house fine all winter.
Hope this is eungh info.
Thank you once again.
HVAC Trane XE70 motor swap-wp_000497.jpg   HVAC Trane XE70 motor swap-wp_000498.jpg   HVAC Trane XE70 motor swap-wp_000509.jpg   HVAC Trane XE70 motor swap-wp_000500.jpg
Lawemail is offline   Reply With Quote
Old 06-23-2013, 11:40 AM   #2
An old Tradesmen
Rewards Points: 6,124
Try high, if too much air, use med high.
Old 06-23-2013, 11:54 AM   #3
How would I connect between picture 1 and 2? I tried a few different ways and can not seem to get it to blow on high. Any ideas?
Last edited by Lawemail; 06-23-2013 at 11:54 AM. Reason: It is stuck on low or med. No high.
Old 06-23-2013, 11:56 AM   #4
Optional there wire connection? Could this be my issue?
Old 06-23-2013, 11:59 AM   #5
An old Tradesmen
Neutral Should go to C of the connector, and he hot to 4 of the connector.
Guessing you have the capacitor wired up to the brown and brown with white strip wires already?
Have you double checked to make sure that rotation is correct.
Old 06-23-2013, 01:12 PM   #6
Cap is wired up yes
Rotation is correct
Just found the high but now I think the outside fuse is blown
Old 06-23-2013, 01:15 PM   #7
I do not have a connectiuide *spelling* tester. So I have Menards test it while I am there for another project.
Old 06-23-2013, 01:18 PM   #8
An old Tradesmen
Continuity. (think I spelled it right) LOL
Old 06-23-2013, 02:38 PM   #9
Ok got a new fuse. Why would the AC fan outside come on only when thermostat set to heat?
Old 06-23-2013, 03:18 PM   #10
An old Tradesmen
May be a shot in the wiring some where.
Trane 3.5 ton HVAC holodeck HVAC 6 06-06-2012 01:21 PM
TRANE HVAC breaker turning off crcuevas HVAC 15 01-14-2012 12:26 PM
advice please! - new TRANE HVAC system ACtawk HVAC 2 10-07-2010 05:25 PM
Trane hvac warranty question jlewi110 HVAC 1 10-21-2009 10:11 AM
Trane HVAC MabelMartin HVAC 2 12-30-2007 10:53 PM
