HVAC Three Wire Motor To Six Wire Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 07:15 PM   #1
HVAC three wire motor to six wire motor
The old compressor fan motor was three wire and the new fan motor is six wire. Brown/white wire to one capacitor connector, Brown wire to other capacitor connector, Purple wire "common" to L1, Black wire "high" to L2, Red wire (low) insulate, Green wire to ground. The old and new capacitor has three connectors, F, C and Herm. The new fan motor shows it being wired to a two connector capacitor. Any ideas
Leo Caproni is offline   Reply With Quote
Old 10-16-2010, 09:26 PM   #2
Did the new motor come with a capacitor?
If it did use that capacitor, if it did not come with one get one sized for the new motor. It should tell you on the data plate of the new motor the size of the capacitor required.
The capacator marked HEM is for the compressor.
The old motor used this original dual purpose capacitor.
Artco is offline   Reply With Quote
Old 10-16-2010, 09:28 PM   #3
An old Tradesmen
Rewards Points: 7,318
F and C.
Old 10-18-2010, 10:56 AM   #4
Thank you guys for your advice but my problem is that the new motor has an extra wire compared to the old motor. The extra wire is brown/white and the wiring instructions on the motor say to wire it to the capacitor. Problem is that the new motor wiring instructions show a two pole capacitor and the old and new capacitor's are both three pole.
Old 10-18-2010, 12:18 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the "three pole" capacitor (three terminal actually) is a dual capacitor. There is a common terminal and then each of the other terminals is the second terminal of that specific section of the cap.
F and C are for the fan ; herm and C are for the compressor
the wires from the motor that hook to the capacitor would go to the "C" and "F" terminals, just like beenthere said.
make sure the capacitor is the proper size for the new motor.
Old 10-18-2010, 01:23 PM   #6
HVAC / Plumbing
Or just buy a cap for that motor & have 2 capicators. The single cap may not be the correct output for that new motor
kenmac is offline   Reply With Quote
wire leads on Reliance Motor abnormalnorman Electrical 13 06-30-2010 09:49 AM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 12:25 PM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Inside Blower motor keeps running crawlerchris HVAC 1 12-19-2009 08:01 PM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 09:57 PM
