HVAC Thermostat Wire - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 02:46 PM   #1
Rewards Points: 121
Hello all. I'm in the process of renovating an entire house, working on drywall in a hallway with an thermostat. Currently I have an old unit I will replace in a few months and would like to go ahead and run the wiring for it now if needed.
The current thermostat uses a 24 gauge telephone wire with 4 solid colors.
What type wire should I run inside the wall for a new, modern unit? Would seem easier to do it now than when a new unit is installed, would it not?
JoeLena is offline   Reply With Quote
Old 01-25-2011, 03:00 PM   #2
Still Learning
You can go to any supply house and buy thermostat wire. I dont remember if it is 18 awg or 20 awg but it is a standard size. As far as how many wires to use depends on what kind of system you are going to install. When futurizing like you are doing, i use 6 strand wire. Here is the breakdown: red is 24v, white is heat, yellow is cooling, green is fan, and i like to use blue for common to power the thermostat. This eliminates having to change batteries in the thermostat. Note: if you are using a heat pump the color code will be different but 6 strand should still work.
thehvacguy is offline   Reply With Quote
Old 01-25-2011, 03:03 PM   #3
Rewards Points: 121
Great, thanks! I'll look for the 6 strand.
Old 01-25-2011, 04:25 PM   #4
Might want to bump it up if you plan on getting more then a single stage heat and single stage cool in the future or plan on adding a humidifier. Mine is 18 gauge 12 wire and every one of them is used.
Old 01-25-2011, 04:39 PM   #5
Rewards Points: 121
Perhaps I'll just put something in to fish some wire thru when it's time. Have good access unser in the basement. Might be over planning things...
Old 01-25-2011, 04:57 PM   #6
Still Learning
Wow you used all 12? The most ive ever used on residential is 8... What requires so many wires?
Old 01-25-2011, 05:21 PM   #7
Two stage gas, two stage HP, humidify, dehumidify, outdoor sensor,R,C,G,O. Actually there's a L terminal not in use,sends and error to the stat if the HP gives a fault. I should have ran 14 wires.
Old 01-25-2011, 05:48 PM   #8
Still Learning
Um... What do you mean by HP? also what furnace you using? And where do you live that you need a hum and a dehum? I think i have installed one dehumidifier in my 5 years doing this, but i live in los angeles so we dont need much
Old 01-25-2011, 06:09 PM   #9
Heat pump. System is a Lennox G61 & a xp19 HP. Dehumidify is just a function of the cooling. It runs the cooling on second stage and ramps the furnace blower way down when the humidity is above a set percentage, mine's on 50%. Design temps in this part of Nebraska are -2 in the winter and 95 in the summer and the humidity is often miserable.
Good place to be in the heating and air biz. LOL
Old 01-25-2011, 06:36 PM   #10
Still Learning
Wow ok. I guess i have a hell of a lot to learn... Well it would be a nice place if there was actually work...
4 wire thermostat to 2 wire Tammpatt Electrical 1 01-10-2011 01:46 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
How to wire in 24vac auxiliary power for thermostat 383bigblock HVAC 6 04-13-2010 07:13 AM
3 wire thermostat shadow82399 HVAC 3 09-20-2009 07:37 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 07:14 AM
