HVAC Thermostat Issues - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 10:05 PM   #1
HVAC Thermostat issues
Last year during summer season my thermostat power went out several times. After varying periods of time it came back on by itself. I've been heating all winter and had no further issues. Yesterday I turned back to air and today the thermostat turned off, just as last year. Has anyone seen this issue before? Seems to be related to only A/C. I've checked circuit box and nothing is tripped. This is also dual zone and the second unit is operating perfectly. Any checks or answers are appreciated. I'm looking to eliminate easy checks before calling a pro.
Thanks in advance
sfmike741 is offline   Reply With Quote
Old 03-15-2012, 05:32 AM   #2
An old Tradesmen
Rewards Points: 6,086
Loose wire connection at the thermostat or or the furnace/air handler.
Old 03-15-2012, 09:15 AM   #3
biggles's Avatar
remove the stat off the subbase and clean the pins or contacts on both with alc.Qtip or pencil eraser are you doing an AUTO change over or manually going from heat to cooling....how old is the stat do you have a C terminal on that subbase?
Old 03-15-2012, 10:37 AM   #4
It's an auto changeover. I'll try cleaning and check the connections at the air handler. Thanks for the help
Old 03-15-2012, 10:38 AM   #5
The unit is 5 years old.
Old 03-15-2012, 11:22 AM   #6
You probably have a float switch in your drain line or drain pan. if your drain line clogs, rather than flooding your home, it creates an open in whatever circuit it is connected to. In this case, probably the red wire for your thermostat. Turn on your a/c, let ut run until the stat looses power. Then, look in your drain pan and in your drain line for two random wires. Follow the wires down to the pan or line and you'll probably also find some water. If you do, get a wet vac, go outside to where your drain line drains and suck out the clog with the wet vac.
jfrotten is offline   Reply With Quote
HVAC Thermostat Deserie HVAC 2 06-17-2011 05:01 PM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
A/C fan issues or thermostat or worse? ct78 HVAC 4 04-10-2011 01:25 PM
Adding second thermostat to HVAC unit hoanphu HVAC 3 12-07-2010 06:24 AM
AC/Thermostat issues rzgwong HVAC 2 06-22-2008 12:08 AM
