HVAC System Running All The Time. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 05:32 PM   #1
HVAC system running all the time.
I was wondering if anyone knew what some possible causes would be for an HVAC system to run all the time and rarely turn off…. I have a Mitsubishi system with two separate controls/thermostats; one upstairs, one downstairs. Whenever I'm heating either floor it seems like they're blowing air pretty much all the time and extremely rarely do they switch off. I've tested the areas and they're both well over 10 degrees hotter then the setting on the thermostat, yet the heating is still belting out… My bills are massive.
Any advice would be appreciated.
xlarge77 is offline   Reply With Quote
Old 02-19-2014, 07:48 PM   #2
sktn77a's Avatar
Rewards Points: 392
Sounds like you've answered your own question - minimally a problem with the thermostat. What are the details? How much space is the system trying to heat? How big is the system? Where are you located? Is this a recent phenomenon (ie during the most recent cold weather)? What temperature are you trying to achieve? How "massive" are the bills?
sktn77a is offline   Reply With Quote
The Following User Says Thank You to sktn77a For This Useful Post:
gregzoll (02-20-2014)
Old 02-19-2014, 11:19 PM   #3
Hi sktn77a,
Thanks for your input. It's a mitsubishi city wide system. Upstairs unit is heating about 700 square foot. The system was new in 2010 but I recently moved in. The bad news is I don't have any cold air returns! I've put a thermometer which reads 75 degrees next to the thermostat which is set to 63. My electic bills this month is about 1k. I live in brooklyn but still... That's ridiculous.
Old 02-20-2014, 10:05 AM   #4
Rewards Points: 52
Does it turn off if you turn it off manually?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-20-2014, 11:06 AM   #5
HI - yes it does turn off manually. I can also change fan speed etc as you'd expect. I'm starting wonder if its due to the room temperature being sensed at the indoor unit and not at the remote controller. I have tried to change this using the remote ( PAC-YT51CRB ) but having trouble.
Old 02-20-2014, 04:42 PM   #6
An old Tradesmen
Rewards Points: 6,592
Measure the temp at the unit.
Old 02-21-2014, 11:53 AM   #7
Hi - I measured the temp at the indoor unit. It's more than 63 degrees there(more like 70) yet the thermostat is set to 63 the heating is running 100%.
Old 02-21-2014, 05:59 PM   #8
An old Tradesmen
May have a bad temp sensor.
Old 02-21-2014, 08:21 PM   #9
Its certainly possible but seems to be happening on both floors.
Old 02-22-2014, 07:43 AM   #10
An old Tradesmen
Is the hole where the line set comes through the wall sealed.
Old 02-22-2014, 09:25 AM   #11
Rewards Points: 52
If you disconnect the up thermostat, does it work correctly? If yes, my guess is upstairs stat. If no, reinstall up and remove down, what happens?
Old 02-22-2014, 09:32 AM   #12
An old Tradesmen
Its a ductless mini split. Should be remote control wireless stats. With internal temp sensors in each cassette. remove a temp sensor, and the cassette goes into error mode.
Old 02-22-2014, 09:34 AM   #13
Rewards Points: 52
Thanks just throwing ideas, wrong ones at that! I guess he should call manufacture?
Old 02-22-2014, 09:37 AM   #14
An old Tradesmen
Yeah, there tech support may or may not talk to him. If they will, they can walk him through trouble shooting.
Old 02-22-2014, 09:46 AM   #15
Rewards Points: 52
Receiver board issue?
HVAC blower not running mreber HVAC 5 05-12-2013 03:08 AM
HVAC advice - entire replacement system including ductwork frankleibo HVAC 1 07-25-2012 09:27 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
advice please! - new TRANE HVAC system ACtawk HVAC 2 10-07-2010 05:25 PM
Old A/C blew, time for a new HVAC unit tburk HVAC 12 09-21-2010 10:25 AM
