HVAC Supply On Load Bearing Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 10:41 PM   #1
HVAC supply on load bearing wall
Hi guys and gals,
Im reworking an old house and trying to get another heat supply to the second floor. House is stucco so the there's basically firring strips on the exterior walls and this is just about the only spot to locate a supply. Based on the joists location I dont have much room to work with. I need to move one stud over about 2.5 inches to give me enough room for a supply. Take a look at the picture and let me know if this is feasible or if there are other alternatives. Thanks a bunch.
grouse is offline   Reply With Quote
Old 08-20-2009, 06:59 PM   #2
sktn77a's Avatar
Rewards Points: 392
You may need to add a couple of additional jack studs on either side of the supply duct gap.
Keith
sktn77a is offline   Reply With Quote
removing load bearing wall from first floor simvt1 Building & Construction 5 05-22-2009 09:15 AM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
Making a load bearing wall a half wall vjbozard Building & Construction 9 04-12-2009 03:11 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
