Hvac Sheet Metal Duct Insulation Type - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2014, 10:29 PM   #1
Hvac sheet metal duct insulation type
Thanks in advance for your input. We are in Phoenix. Our attic has the sheet metal type of ducting. It has blown in insulation over the ducting. We have the ducting exposed right now (blown in insulation moved to the side) and there is also no foil tape or mastic on the seams. The unit is a roof top HVAC, 2 ton. There is probably about 20 feet of duct and you can only get to the top and sides of it.
What is the best stuff to wrap the ducting with? Foil tape and mastic on the seams? Anyone use foam board cut to size? Home depot sells R6 duct insulation but not sure if that is enough of an R value.
beach_n_rides is offline   Reply With Quote
Old 03-12-2014, 06:31 AM   #2
An old Tradesmen
Rewards Points: 6,480
Seal all seams top and bottom first, then use foil faced duct wrap.
Old 03-12-2014, 08:50 PM   #3
Rewards Points: 154
use R-8 duct wrap insulation. Seal the joints first
Patrick Eubanks is offline   Reply With Quote
Old 03-14-2014, 01:49 PM   #4
Rewards Points: 314
I can tell you what worked for me... I am in tempe so it should work for you.
I covered mine with two layers of r13 24 inch wide bats. Then I covered all that with a radiant barrier. I also added some insulation in side of the package unit on the roof.. doing all that really helped!!!!
bobbinphx
bobinphx is offline   Reply With Quote
flex duck vs metal duck fhammette HVAC 21 12-19-2011 07:30 AM
OK To Bend A StrongTie Sheet Metal Hanger Connector? Gordo Burgess Building & Construction 5 10-12-2011 08:55 PM
Sheet metal under a rubber roof? what is going on here? philasheetmetal Roofing/Siding 2 07-12-2011 09:12 AM
Cold back room - question on duct insulation crazykidsdad HVAC 4 12-13-2010 01:59 PM
Transistion from Duct Board to Sheet metal zootjeff HVAC 0 06-29-2009 01:05 PM
