HVAC Service Valve Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 04:08 PM   #1
HVAC service valve replacement
A technician looked at my HVAC compressor and said the service valve was "ceased and rusted" so he could not check it. Is there no way to replace this valve rather then getting a new compressor? Wants to charge 1,000 for a new compressor. Thanks Dick
Demersr1 is offline   Reply With Quote
Old 06-09-2011, 04:15 PM   #2
Rewards Points: 1,216
Why was he called in the first place ? What was wrong to make you call?
COLDIRON is offline   Reply With Quote
Old 06-09-2011, 04:36 PM   #3
How old is your unit?
Hubcap626 is offline   Reply With Quote
Old 06-09-2011, 04:38 PM   #4
there are too many variables here to answer your question. whay did you call out a techniciina? how old is the unit?.....etc
cascadehvac is offline   Reply With Quote
Old 06-09-2011, 04:40 PM   #5
Rewards Points: 150
you sure can replace it, cut it out and install a new one.
http://americanhvacparts.com/Merchan...=ServiceValves
alecmcmahon is offline   Reply With Quote
Old 06-09-2011, 07:43 PM   #6
Replace the valve or have him braize on another access port called a tap-a-line. I've used the add on port before on old units not worth the cost of replacing a rusted up king valve.
Old 06-09-2011, 08:22 PM   #7
Thanks Guys!
He was called originally because the unit (both inside and out) would not turn on. He diagnosed the issue as a bad circuit board in the inside unit (furnace?) He said both the thermostat was fine and the blower was fine but power was not getting beyond that circuit board. REpair bill is $500. He looked at the outside unit to check it out and that's when he said the valve was rusted and ceased and eventually it would need to be repaired at a cost of $1,000.
Having said all this, let me include that all this info has been relayed to me by my son who is at the house. I am not on site but am trying to gather as much info as I can. The compressor replacement is a guess on my part because I can't imagine replacing that valve would cost that much. Am I wrong on that assumption?
Old 06-09-2011, 08:23 PM   #8
I forgot to mention that the unit is about 8 years old.
Old 06-09-2011, 08:28 PM   #9
Rewards Points: 150
Seems steep to me, but I've never had an HVAC tech price anything out for me.
He'd have to evacaute all the refridgerant out of the system into a storage tank.
once all the freon is recovered all he'd have to do is cut out the old service valve, braze a new one in, then - pull a vaccumm on the system then re-fill with freon.
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Mixing Valve replacement mediaman67 Plumbing 20 03-02-2010 10:19 PM
Leaky showerhead after valve replacement mr.perplexed Plumbing 3 01-30-2010 03:05 PM
shower valve replacement bigdaddypalmer Plumbing 4 01-02-2010 10:06 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
