HVAC Runs And Runs - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2016, 11:06 PM   #1
Rewards Points: 54
HVAC runs and runs
My AC is in Heat mode now since its winters.
The current temperature inside house is 70.
I have my HVAC set to 69. It will be off and wait till temperature drops below 69 and then heat will kick in and heat he house...
ALL OK SO FAR.
Now problem is ... lets say the temperature does not drop below 70 inside house , the HVAC will still kick and start blowing cool air (not chilled) but regular recycle (atleast not heated air) and keep blowing ... It bothers me since my side of bed is directly under vent and I hate someone blowing air at me in winters if its not HOT.
what is the problem ? Is there any setting ? I have ecobee wifi thermostat.
PLEASE HELP
panthar is offline   Reply With Quote
Old 01-05-2016, 11:19 PM   #2
Rewards Points: 7,132
We don't know what kind of system it is.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is offline   Reply With Quote
Old 01-05-2016, 11:21 PM   #3
griz's Avatar
Rewards Points: 570
sounds like you have the system fan on cycle.
griz is offline   Reply With Quote
The Following User Says Thank You to griz For This Useful Post:
supers05 (01-06-2016)
Old 01-06-2016, 07:53 AM   #4
Rewards Points: 46
When the system is on "circulate" or whatever ecobee calls it, it will try to even out the air in your house when the unit hasn't run for a while. It'll be setting in the thermostat
Cheers!
supers05 is online now   Reply With Quote
Old 01-06-2016, 11:29 AM   #5
Rewards Points: 54
I actually checked all the option in the thermostat controller .. I did not see anything which says FAN ON / CIRCULATE / AUTO.
Only option I see it FAN ON / AUTO .... it set to Auto ... and is set on 0 Min/hour ...
I can set 5 Min/hour and likewise ... if I put it to ON ... then fan starts running immediately ... It has some installer menu and I did not find any option there either ...
Old 01-06-2016, 04:08 PM   #6
Rewards Points: 272
It's probably on circulate.. Assuming you can't figure out how to change it .. I have no idea about your thermostat's settings ... you should be able to get an air vent deflector to redirect the air from your vent.
crabjoe is offline   Reply With Quote
Enlarging two 6" runs Rewound98 HVAC 17 01-10-2013 02:44 PM
Hvac runs hot air sometimes, should be cold. jdavlaw HVAC 8 05-18-2012 03:03 AM
insulating and insulated duct runs hummer4x4guy HVAC 4 01-09-2012 03:52 PM
a/c runs for many hours maybe return vent issues ddeennis HVAC 24 08-02-2011 05:54 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
