Old 01-10-2013, 08:07 PM   #1
HVAC Return
I am reworking my hvac return, routing front crawl space where the unit is, to the attic where I would like to run all my returns to each individual room by dropping each in the ceiling. I have a 5 ton heat pump/ac system. I plan to run 2 20x20 return ducts from the crawl space to the attic. I would like to know it it is ok to box in a section of my utility room using sheet rock material to box it is, instead of using metal duct work?
mwalls963 is offline   Reply With Quote
Old 01-10-2013, 08:25 PM   #2
Devil Dog
handyman_20772's Avatar
HVAC Return
Duct work, including returns shouldn't be in any unconditioned space (attic or crawl space). But if you are gonna construct one use metal and properly seal all your joints and insulate it as well. Drywall can be used to surround the metal return, but I would never use it as a return.
handyman_20772 is offline   Reply With Quote
Air return for roof mounted HVAC in AZ Benbear8 HVAC 0 11-12-2012 12:45 AM
Return Air Issues in old Pier and Beam House Hiker HVAC 0 10-01-2012 06:56 PM
understanding hvac... cold air return questions Shawnzy HVAC 3 09-05-2012 07:25 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
