HVAC Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 08-15-2012, 02:20 PM   #1
HVAC replacement
Anyone have an old system replaced recently? I need a complete overhaul and am curious about what I am about to pay. I live in the DFW area.
My unit is undersized and has bad coils. Plus I am pretty sure its the original unit which would be 1996.
bbelmont83 is offline   Reply With Quote
Old 08-15-2012, 08:20 PM   #2
Rewards Points: 16
Just a guess new furnace, coil and condensor 4 to 6 k depending on brand and efficiency.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-15-2012, 08:29 PM   #3
Rewards Points: 582
you really won't get any prices here....get a local company to come and see the job..if its undersized ..they can do a load cal and size it right and check ductwork as well...ben sr
Old 08-15-2012, 08:33 PM   #4
Missouri Bound's Avatar
Three things to consider when replacing a system.
1. Make sure the contractors(s) bidding give you calculations as to what size unit you need, not just relpace what is there.
2. Get references from all contractors and actually check them.
3. Get at LEAST 3 bids, and make sure they are all comparing the same type of installation..
Of course there are more, but common sense will be very important in making your decision, and this forum is full of suggestions and opinions.
Do you want it your way or the right way?
Does this look like asbestos wrapping my HVAC register? htabbas HVAC 12 11-22-2011 07:15 AM
Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? cmgoss HVAC 1 06-29-2011 06:12 PM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 05:28 AM
Estimate for Basement HVAC in New Construction jb_nc HVAC 4 07-29-2009 12:48 PM
