Hvac Relay Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 09:37 AM   #1
Hvac relay problem?
Hi.
We have a 17 year old Trane hvac in our 2000sf Florida home. My home office sits on the opposite wall where our air handler is located in the garage, so I hear the ac kicking on and off all day.
Recently, though, the ac will kick on, run until it hits the temperature, then kick off YET, several times during the day, after it kicks off, it will immediately try kicking back on, then off, then on, then off, kind of like a car trying desperately to start. After it cycles on off, on off, it will then kick back on and run again for several minutes.
My ac guy said the thermostat was fine yet of course, the system would not do the "on off on off" while he was here. He mentioned it may just be the relay. Any thoughts?
Thank you!
tatums4 is offline   Reply With Quote
Old 05-01-2011, 09:53 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Do you know, maybe something you can check while this is happening, if the outdoor unit is trying to start and stop while this is going on or if it is just the blower in the air handler that is doing it?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-01-2011, 11:17 AM   #3
An old Tradesmen
Rewards Points: 7,760
As above, if its just the indoor fan you hear, good chance it is the fan delay relay.
Old 05-01-2011, 11:36 AM   #4
Good question, hvactech126! The air handler started the on off on off cycling and I immediately ran to the outside unit. It DID NOT try to turn on. So what's the expert opinion now?
Thanks, again!
Old 05-01-2011, 11:39 AM   #5
AKA HVACTECHFW
Most likely a fan relay inside the air handler.
IT IS WHAT IT IS
Old 05-01-2011, 12:04 PM   #6
Thanks for the quick feedback!
Should I let the on off on off cycling continue until the relay dies or would it be smarter to have the relay replaced this week? Any implications for just letting it continue or would a new relay help with the operating efficiency?
Old 05-01-2011, 12:25 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 92
Get the relay replaced ASAP. If it fails to turn the fan on the evaporator coil/A coil will freeezup and liquid refrigerant will slug back to the compressor and seriously damage it.
Old 05-01-2011, 12:42 PM   #8
Thank God for this website!!! I will have the relay replaced tomorrow. Very much appreciated for the feedback!!!!!!!!!!!!!!!!
Coke vending machine problem, hvac techs take a look tamar120 Appliances 13 04-22-2012 06:19 AM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
HVAC fuse problem linnage HVAC 1 06-01-2010 06:10 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
