HVAC Register Question - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 03:04 PM   #1
Hello experts,
I'm remodeling my basement and need help determining if I should ADD a register and ADD a return. See the attached pic. I'm thinking about running the 6" tube into the "false" soffit and split it at a tee and have the registers reside in the soffit.
I also have the return air from the 2nd flr of the house coming into this room. Should I bust into this return and provide return from the basement?
Thanks for the help,
Brandon
bphyatt is offline   Reply With Quote
Old 12-15-2009, 03:45 PM   #2
A 6" supply isn't big enough to carry the volume of air needed for 2 registers. If you increase it to 8" all the way back to the trunk it might work. I wouldn't ruine an upstairs return like that or put a basement return in a ceiling. Any way to tap the return drop and go through a wall?
Old 12-15-2009, 05:07 PM   #3
Yeah, unfortunately there's no way to get the return into the wall. I figured it wasn't a good idea to have the return in the ceiling, but wanted to confirm. What if I put two 2x10 registers, would the 6" still be enough?
Old 12-15-2009, 05:12 PM   #4
An old Tradesmen
Rewards Points: 7,262
Nope.
You won't get the air to throw down to the floor.
Either use an 8" as suggested. Or 2 separate 6" supply runs. If you want it to actually be some what warm in the basement.
Old 12-15-2009, 08:03 PM   #5
You want >600 FPM for this?
Old 12-16-2009, 05:27 AM   #6
An old Tradesmen
Need to choose the correct register.
A H&C 682M 2 way at 70CFM and 600FPM only has a throw of 6 foot.
But the 681M 1 way 70CFm and 500FPM has a throw of 8 foot.
He would probably be better off using H&C A618 10X4. That would give him the ability to throw 100CFM 9.5 foot at 500 FPM. Making it fairly quite.
And it still has a throw of 6 foot at 60 CFM at 300FPM.
Old 12-17-2009, 08:57 AM   #7
register throw
http://books.google.com/books?id=J_R...row%22&f=false
New Drain for HVAC Condensate Pump LoveMyHome Plumbing 6 12-05-2009 06:59 AM
Trane hvac warranty question jlewi110 HVAC 1 10-21-2009 09:11 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
