Hvac R22 Unit Replace With 410 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 03:52 PM   #1
hvac r22 unit replace with 410
compressor is bad on 5 ton r22 outdoor unit, i have a 4 ton, never been used 410 unit, can i install this outdoor unit to replace bad 5 ton unit
mikeds is offline   Reply With Quote
Old 07-25-2012, 04:13 PM   #2
no not without changing the indoor unit. If you need 5 tons you will not be happy with 4
turnermech is offline   Reply With Quote
Old 07-25-2012, 05:23 PM   #3
Rewards Points: 1,216
Sounds like time for a new 410 system.
COLDIRON is offline   Reply With Quote
Old 07-25-2012, 07:34 PM   #4
An old Tradesmen
Rewards Points: 7,356
First, a 4 ton condenser won't have the capacity of a 5 ton. So does your house really need a 5 ton, or a 4 ton? Next, how old is the indoor unit/coil.
An indoor coil can be flushed/blown out well enough to use it with R410A, but you will need to change the metering device to one sized for R410A and for a 4 ton unit.
After doing all this. you could end up that you really needed the 5 ton, and have a very hot house most of the time.
A load calc would tell you if the 4 ton can handle the load.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (07-26-2012)
Old 07-25-2012, 08:50 PM   #5
Rewards Points: 582
don't waste time and money do a load calc on the house 1st to see if 4 ton will handle it..if it will...apply the above information ..ben
Old 07-25-2012, 10:01 PM   #6
Rewards Points: 616
nope
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Can I install an HVAC unit myself? Madix HVAC 40 02-21-2012 02:48 AM
Trap Needed on HVAC Unit? dixie2bird HVAC 3 10-28-2011 08:10 PM
Why HVAC people want to replace unit and not coil? pcumming HVAC 4 05-21-2011 09:57 PM
Building HVAC Instructional Unit lbagot HVAC 6 08-02-2010 05:31 PM
Furnace blew up, need to replace heat and air with single unit. d_Random HVAC 2 02-06-2007 04:18 PM
