Old 07-09-2012, 02:54 PM   #1
Hvac questions
How do u wire a two proung capacitor when you had a three proung capacitor already. Where do the wires go from your ac unit
Damiens is offline   Reply With Quote
Old 07-09-2012, 03:54 PM   #2
Hvac questions
You have to use a 3 proung cap to replace a 3 proung cap. (unless you use 2 2-proung caps to replace 1 3-proung cap)
clocert is offline   Reply With Quote
Old 07-09-2012, 08:42 PM   #3
Hvac questions
Be careful that three prong cap might be a duel cap used for two reasons, one for a fan the other for a compressor. Check it carefully before replacing it.
COLDIRON is offline   Reply With Quote
Old 07-09-2012, 09:48 PM   #4
Hvac questions
3 proung capacitor supports 2 motors, one fan motor, the other one is compressor, so the 3 proung has 'fan', 'herm', and 'com' 3 terminals. 'fan' and 'com' connect to your fan, 'herm' and 'com' connect to your compressor. If you use 2 proung capacitors, you need 2 of them. one supports fan and the other one supports compressor. It is hard to draw a diagram here, may be you can find some pictures on the web.
I borrowed a diagram from another forum, hope this help......
Last edited by clocert; 07-09-2012 at 10:05 PM. Reason: Add a diagram..Borrowed from another forum
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Grounding Questions ZBat910 Electrical 61 09-09-2011 03:45 PM
Couple of HVAC questions... Don't know where to start.. jfoust HVAC 0 08-02-2011 10:34 PM
Basement Finish HVAC questions JETJR HVAC 3 06-15-2009 03:06 PM
HVAC questions z28clone HVAC 1 05-23-2009 07:10 AM
