Hvac Question - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 07:51 AM   #1
Hvac question
I have a trane unit model - TTA060C400A0.
And its a straight cool not heat pump.
When in cool mode, the outside unit put out heat from all sides around the unit but not from the top. Why? Please help me on this.
ryandeen is offline   Reply With Quote
Old 04-16-2013, 08:45 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
it should not do that as the fan is now running backwards. very good chance the capacitor is faulty. rare but when it fails the fan can do that. either that or someone wired it up wrong. if it worked OK B4 then it may be the cap.
Old 04-16-2013, 08:48 AM   #3
Thank you Yuri, I well check the cap or just change it out
Old 04-16-2013, 11:53 AM   #4
I check the cap for the fan and its rated for 7.5 mfd. when check with my meter it read 6.9.
And last spring we change out the fan blade, if that is installed upside down, would that cause that to happen also.
Old 04-16-2013, 03:22 PM   #5
An old Tradesmen
Rewards Points: 6,824
Yes it could. Are you sure its even the right fan blade.
Old 04-16-2013, 07:58 PM   #6
Lol, yea it the exact fan blade from graingers..
Some one told me try switching the wires around on the capacitor. The cap did not have C or F on it. So I couldn't tell.
By the way this is for a hotel up town Charlotte that I work for.
Old 04-17-2013, 03:40 AM   #7
An old Tradesmen
A weak cap can cause a fan motor to run backwards.
Old 04-17-2013, 09:48 AM   #8
Rewards Points: 446
Can you see the hub where the screw is to tighten down the fan onto the motor shaft when looking at the unit from the top?
You shouldn't be able to.
old_squid is offline   Reply With Quote
Old 04-17-2013, 05:09 PM   #9
AKA HVACTECHFW
Rewards Points: 1,208
Grainger doesnt carry Trane parts.........
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-17-2013, 06:25 PM   #10
Experienced HVAC Tech
HVAC1000's Avatar
True but Trane doesn't make their own fan blades. Trane uses GE fan blade. Grainger sell GE fan blades. If its the same manufacture number it's the same blade
HVAC1000 is offline   Reply With Quote
Old 04-18-2013, 08:43 AM   #11
It's looks exactly like the same blade, the hotel only have an account with granger . And I check , I cannot see the lock nut from top. But the AC still works great. Just taking the heat out the wrong way. I will try switching that fan Blade around when I get a chance. Thanks guy.
Old 04-23-2013, 06:54 PM   #12
Ok guys I found the problem . I first switch the fan blade around and same thing happen then I switch the wires on the capacitor around brown and purple and then the fan blade start rotate in the other direction . All heat comes out of top now and non on the sides.
But thank you guys for trying to help me figure this out.
HVAC cold air return question cmccarter HVAC 12 05-02-2013 08:15 PM
HVAC Question Mabrins HVAC 12 01-22-2013 02:33 PM
Furnance HVAC question joetorres HVAC 1 11-27-2011 08:02 PM
HVAC Humidifier Question rubicon789 HVAC 8 01-13-2009 11:06 AM
Question, HVAC or elect. Yoyizit HVAC 12 08-10-2008 08:17 AM
