HVAC Pros:would You Do It His Way? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 09:15 AM   #1
HVAC Pros:would you do it his way?
I just shook my head.
Judge for yourselves.
http://www.youtube.com/watch?v=Y5s72...eature=related
hvac5646 is offline   Reply With Quote
Old 01-04-2012, 09:19 AM   #2
the Musigician
DangerMouse's Avatar
You might want to just post a link, the forum does not allow embedded video viewing.
DM
Old 01-04-2012, 10:15 AM   #3
biggles's Avatar
youtubes work good
Old 01-04-2012, 06:40 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
I like his plastic gloves. If those catch on fire he will need major skin grafts. I use an oxy acetylene and can weld those joints in 1 minute.
Old 01-04-2012, 06:49 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I've never done that and I have a question.
Why does it take so long for the copper to get up to temperature?
Was he scaulding the metal or is that how long it takes?
If so...why?
It never takes that long to solder that size copper fittings.
What am I missing?
XXX
Old 01-04-2012, 06:58 PM   #6
Hvac Pro
yuri's Avatar
he was blowing nitrogen thru at 10 psi when we normally use 1 psi. blowing away the heat and he is using a large blowtorch type flame. I prefer a smaller hotter oxy acetylene precision tip/flame. He cooked it good.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (01-04-2012), Bud Cline (01-05-2012)
Old 01-04-2012, 07:12 PM   #7
Oxy/ace is faster Bud. Solder has a much lower melting point then the 15% silphos used so it takes what it takes to get the pipe up to 1100+ degrees. Using oxy/ace those 2 elbows would have been done in about 1 minute instead of the 6 minutes it took using a B tank.
The Following User Says Thank You to Marty S. For This Useful Post:
Old 01-04-2012, 08:18 PM   #8
An old Tradesmen
Rewards Points: 7,376
Yep, too much nitro at first, and he had the torch too far a way. I can braze 1 3/8" faster then that with a Turbo.
He should use a flow reg to flow his nitrogen.
Old 01-05-2012, 01:50 AM   #9
i would not do it this way
zxas6699 is offline   Reply With Quote
Old 01-05-2012, 07:59 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What's the reason for the nitrogen?
XXX
Old 01-05-2012, 08:03 AM   #11
Hvac Pro
yuri's Avatar
prevents carbon from forming inside the joint and later getting into the system and plugging up components. if U weld in an oxygen free environment carbon does not build up. nitrogen displaces the oxygen.
The Following User Says Thank You to yuri For This Useful Post:
Old 01-05-2012, 09:20 AM   #12
Anybody catch the vibration eliminator in the line? I grantee you that bellows in the eliminator is fried and full of burn holes.
I hope he learns from the post he is going to get.~snicket~
Old 01-05-2012, 10:39 AM   #13
Hvac Pro
yuri's Avatar
Anybody notice the fact he is using an open flame close to some LARGE battery chargers for those forklifts. Last time I heard batteries can give off explosive gases when charging and KABOOM.
Old 01-05-2012, 01:16 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Safety equipment (eye protection in this case) is not a pre-requisite south of the border I suppose?
XXX
Old 01-05-2012, 01:21 PM   #15
An old Tradesmen
See a lot of guys not wear safety equipment around here. Makes no difference whee people are from, some just don't care/think.
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
