HVAC Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 04:37 PM   #1
HVAC problem
Hi, I have an old Carrier furnace, circa 1983. The filter is good. The pilot light is on. When I set the thermostat to ask for heat, I hear it fire. The heat never blows into the ducts.
I went upstairs and looked, the pilot light is still on and the "box" labeled heat is hot, and the exhaust from it to the roof is warm with hot air.
When I turn it off, and then turn the fan controls on, the fan does run.
I've heard it fire on two or three different occasions, but the air never blows through the ducts.
Help!
briancrisp is offline   Reply With Quote
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
Problem with Furnace during Night Only Dior55 HVAC 2 02-20-2009 01:16 PM
Inefficient HVAC. Rasputin HVAC 12 06-13-2008 08:22 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
