Which HVAC Packaged Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 09:30 AM   #1
Which HVAC Packaged unit
I am replacing my Bryant gas pack. I have the following estimates:
Trane 4Ton gas pack 16 SEER $
(Model # 4ycz6048A1096A)
20 yr heat exchanger
12 yr compressor
10 yr parts
1 yr labor
Trane 4Ton gas pack 14 SEER $
10 yr compressor
5 yr parts
1 yr labor
Amana 4Ton gas pack 15 SEER $
(Model # APG154911541AA)
Lifetime heat exchanger
Lifetime compressor
10 yr parts
10 yr labor
Any recommendations?
Thanks.
Rob
Soetekouw is offline   Reply With Quote
Old 02-22-2010, 10:09 AM   #2
Rewards Points: 502
Do all three qualify for the tax credit?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-22-2010, 10:14 AM   #3
The Trane 16 SEER and the Amana 15 SEER has the tax credit.
Old 02-22-2010, 11:45 AM   #4
Rewards Points: 1,910
That's quite a nice warranty on the Amana. No point considering the 14 SEER Trane since the Amana gets you more for less. You could run some numbers to try to estimate whether the 16 SEER would save you much over the 15 SEER. Then try to guess how much the Amana 10 year labor warranty will save you.
I have no idea how rugged/reliable the three units are.
Old 02-22-2010, 02:48 PM   #5
An old Tradesmen
Rewards Points: 8,142
Use the best contractor, don't worry about brand name.
Old 02-22-2010, 05:58 PM   #6
Most of the equipment manufactured today is of good quality and the Quality Control Techniques are stringent.
When you spend x amount on a new system the contractor's reputation and workmanship are the most important.
Get names and numbers call people find out who's the best call the BBB do some homework.
Remember the low bid is not always the best.
Also don't spend thousands for a unit just because your getting a little tax break.
SULTINI is offline   Reply With Quote
Old 02-22-2010, 06:27 PM   #7
Lifetime heat exchanger and lifetime compressor warranty looks mighty good! Of those three choices I'd buy the Amana. Ask if parts are available local when it breaks down or if they have to be ordered , both brands.
Old 02-22-2010, 10:31 PM   #8
Brands don't matter so much. All manufacturers are going to have defects now and again. As was said before, it's definitely the contractor that makes the difference, both for installation and service. Perhaps the best of them can switch their equipment to match your goals rather than push a certain brand.
Keep in mind, if you live in an area with mild climate your contractor should be recommending an economizer.
Pavel is offline   Reply With Quote
HVAC unit not heating Lace HVAC 3 01-03-2010 09:47 PM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
Why is water coming out from the bottom of the HVAC unit? Woz HVAC 11 08-02-2009 08:38 AM
new hvac precharged unit install reno1011998 HVAC 1 01-30-2009 02:37 PM
HVAC unit moves too much air - can I slow the fan down? UtahGuy HVAC 7 12-16-2008 06:06 PM
