HVAC Options For Very Small Cabin/shack - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 03:05 PM   #1
Rewards Points: 224
HVAC options for very small cabin/shack
We need to add a quick building at a remote property to lay our head when we are on site. The main focus of this project is fast and cheap. Approx SF will be 500 to include 2 bed, 1bath, and kitchen/living area. I am looking for a simple and economical way to heat/cool it. We will have 200A of electric on site, no nat gas, but could have propane. However, in comparing costs of propane and electric per BTU, and the fact that we will not run it more than maybe 1-2days/mo, electric seems the wiser choice.
A heat pump setup is obviousy better for heat but not sure if the cost will be offset. Resistive baseboard heats seem too expensive and too much work for what you get. I was really considering a system where the evap and condenser are built together and you just add ducting (not sure what you call them). I have also considered the basic window unit with built in resistive heating. I would prefer some minor ducting to make sure the rooms stay comfortable but no need to go nuts here.
Ideas?
viper is offline   Reply With Quote
Old 07-25-2012, 05:25 PM   #2
A hotel type unit (PTAC) make sure heat pump version. No ducts to run to other rooms but cheapest
turnermech is offline   Reply With Quote
Old 07-25-2012, 08:06 PM   #3
Rewards Points: 266
If it it does not get too cold for heat pumps, how about heat pump window units? After Katrina, I rented an apartment with two of them as the whole heat source. They worked fine if you think that window units are fine.
ionized is offline   Reply With Quote
Old 07-25-2012, 09:42 PM   #4
I would not be suprised to find out they now make heat pump window units. I have never seen one or heard of one. i know they have window units that heat and cool but they are heating with electric heating coils not heat pump.
Old 07-25-2012, 09:46 PM   #5
biggles's Avatar
BARD makes HP units used in construction trailers...and i remember there were window unit heat pumps back in the 80s before the ductless happened
Old 02-11-2013, 11:38 AM   #6
Special User
Rewards Points: 1,230
I realize I'm resurrecting an old thread, but I had the same experience -- window-size heat pumps are incredibly rare. I know I'm too late to help the OP, but for anyone Googling this, I finally found one and just installed it: Amana's "AH" series. They have A/C and heat pump modes, as well as emergency resistance heat as a backup for when it's too cold outside. Note, the AH series all appear to require 240V.
I've only had mine for two days, but so far it works great as a heat pump.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Small 2 Bedroom, 900 sq. ft. Home HVAC System Questions markcr HVAC 7 04-18-2011 08:05 PM
HVAC for small spaces stubits HVAC 1 02-10-2010 03:26 PM
wall options for small bedroom Bigguy0 Building & Construction 3 01-23-2010 05:01 PM
Color options for a small cape style home Staticman2 General DIY Discussions 2 06-20-2009 01:53 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 12:06 PM
