HVAC Not Working Properly, Zone System - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 10:13 PM   #1
HVAC not working properly, zone system
Our hvac has never worked right. Not sure if the duck work is right. contractor went bankrupt at the end of our job. The inside unit has ran for 8 hours and has not pulled the temp up the 3 degrees we asked. temp outside was about 49 now is about 39. It is 5 tons outside. The outside unit has cycled on and off about every 5 minutes. The inside has stayed on. The second zone has not came on all day we did not need it to. No one can figure this out. The thermostat is Robert Shaw and I think the zone system is zonex and the outside unit is American Standard. The third top floor has a single unit, 3 tons. The loft open to the middle floor which is on the other 5 ton unit. I hope this makes since. Please help.
terrishan is offline   Reply With Quote
Old 11-06-2010, 07:21 AM   #2
update
Our airhandler ran all night never turning off. Does anyone have any ideas of what might be going on? Thanks. Any ideas would be greatly appreciated.
Oil Baseboard zone not working mirx HVAC 2 10-19-2010 04:20 PM
Zone system retrofit possible? perpetualjon HVAC 2 07-14-2010 05:23 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 12:07 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 06:04 PM
