HVAC New Blower Motor, Which Speed? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 11:49 PM   #1
HVAC New Blower motor, which speed?
Hi, I just replaced the blower motor in my Trane HVAC/Heat pump unit. The old motor wouldnt turn on, even if I spun it with my hand. I bought a universal replacement (much cheaper and in stock), and it blows great now.
The question is, what speed should I use on the motor? It has high, medium, and low. I "think" the old motor was on medium (as best I can tell by the wiring diagram).
Should I put the new motor on medium also?
I have it on high now, and it blows great, but it seemed to be a little slow in cooling down the house. Maybe I am asking alot for it to cool the house down from 90. It has been running for 2.5 hours and the temp is just now 83.
Also, it seems a little bit weird that the blower motor has several speeds, but the unit only uses one of them. Was it supposed to use all three? Trane model # TWE048P130A0
Thanks for any help! Ken
kenimpz00m is offline   Reply With Quote
Old 09-14-2010, 05:27 AM   #2
An old Tradesmen
Rewards Points: 6,576
If the old motor was connected to use med speed. Connect the new motor the same way.
It takes a long long time to cool a house down when its 90 inside.
It has 3 speeds because not all units need the same speed.
Old 09-14-2010, 10:25 PM   #3
I changed the speed to medium. It never really seemed to cool exactly as before. I am hoping that by slowing it down, it will cool it better.
Old 09-27-2010, 04:08 PM   #4
Hi Ken, I have the same model as yours and I would like to ask you where did you buy the motor and how much did it cost? I'm going to have to replace mines soon.
Thanks,
magnum68
magnum68 is offline   Reply With Quote
Old 09-27-2010, 04:11 PM   #5
old post. Not likely to get a reply...but it don't hurt to try.
hvaclover is offline   Reply With Quote
Old 09-27-2010, 04:41 PM   #6
OLD? His post was made 13 days ago.
Old 09-27-2010, 04:46 PM   #7
and the problem was resolved then also. His post count would indicated that he is not a regular on this board so I would suggest you post a new thread and ask your question.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Help with HVAC blower motor wiring Jcpilot Electrical 4 03-18-2012 03:28 PM
hvac blower vs capacitor, does my conclusion make sense? Lalan64 HVAC 2 07-17-2010 09:24 AM
Variable speed Blower konqwest HVAC 4 12-01-2009 05:45 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 11:01 PM
