-   -   HVAC New Blower motor, which speed? (http://www.diychatroom.com/f17/hvac-new-blower-motor-speed-81391/)
kenimpz00m 09-13-2010 10:49 PM
Hi, I just replaced the blower motor in my Trane HVAC/Heat pump unit. The old motor wouldnt turn on, even if I spun it with my hand. I bought a universal replacement (much cheaper and in stock), and it blows great now.
The question is, what speed should I use on the motor? It has high, medium, and low. I "think" the old motor was on medium (as best I can tell by the wiring diagram).
Should I put the new motor on medium also?
I have it on high now, and it blows great, but it seemed to be a little slow in cooling down the house. Maybe I am asking alot for it to cool the house down from 90. It has been running for 2.5 hours and the temp is just now 83.
Also, it seems a little bit weird that the blower motor has several speeds, but the unit only uses one of them. Was it supposed to use all three? Trane model # TWE048P130A0
Thanks for any help! Ken
beenthere 09-14-2010 04:27 AM
If the old motor was connected to use med speed. Connect the new motor the same way.
It takes a long long time to cool a house down when its 90 inside.
It has 3 speeds because not all units need the same speed.
kenimpz00m 09-14-2010 09:25 PM
I changed the speed to medium. It never really seemed to cool exactly as before. I am hoping that by slowing it down, it will cool it better.:confused1:
magnum68 09-27-2010 03:08 PM
Hi Ken, I have the same model as yours and I would like to ask you where did you buy the motor and how much did it cost? I'm going to have to replace mines soon.
Thanks,
magnum68
hvaclover 09-27-2010 03:11 PM
old post. Not likely to get a reply...but it don't hurt to try.
magnum68 09-27-2010 03:41 PM
OLD? :no: His post was made 13 days ago.
hvaclover 09-27-2010 03:46 PM
and the problem was resolved then also. His post count would indicated that he is not a regular on this board so I would suggest you post a new thread and ask your question.
