HVAC Multi Zone - HVAC - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 09:01 PM   #1
HVAC Multi zone
My HVAC system that is being installed is multizoned. it consists of two zones, each controlled by a damper on the supply. Each room has a return vent rather than one central return in the house. My question is should dampers also be included on the returns too or just the supplies?
skippy76 is offline   Reply With Quote
Old 08-30-2009, 09:11 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
IMO just the supplies. The return needs to be as free and open as it can. No restriction to the air being drawed into the furnace
I like the return to all the rooms better than the central return. Just remember no returns in the kitchen and bathrooms
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-30-2009, 09:13 PM   #3
ok, thanks. I was just ponderring as if zone 1 is active, with no dampers on the returns to zone 2 the air will be drawn from zone 2 even when just conditioning zone 1. The furance is a VS so will compensate.
Andrew
Old 08-30-2009, 09:20 PM   #4
Rewards Points: 560
Is this a 2 stage furnace?
Old 08-31-2009, 08:00 AM   #5
Yes, it is actually 3 stage, variable speed.
Old 08-31-2009, 08:34 AM   #6
30 year tech
hvac122's Avatar
No, dampers are not needed in the returns. What brand zone system are you using?
hvac122 is offline   Reply With Quote
HVAC very weak upstairs with zone control installed g8rben HVAC 5 06-14-2009 06:51 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
Adding another HVAC Zone handy man88 HVAC 3 10-09-2007 09:45 PM
