HVAC Meter Recommendations - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 04:12 PM   #1
HVAC meter recommendations
I just saved a bunch replacing the faulty capacitor and condenser fan motor on my home air conditioner myself. So I want to spend some of that on a new meter that would have come in handy on that repair. I would appreciate recommendations for a general purpose meter that includes capacitance and inductive voltage. I'd like to spend less than $150. Thanks, Frank
flanso is offline   Reply With Quote
Old 10-12-2011, 04:29 PM   #2
Rewards Points: 1,522
Flanso,
For the cost of a new capacitor (~$30), you could buy 5 meters. An inexpensive analog VOM is all that is needed IMO for a homeowner.
You shouldn't need to do this kind of repair every year; maybe every 5 or more years.
bob22 is offline   Reply With Quote
Old 10-12-2011, 05:15 PM   #3
biggles's Avatar
sears ....harbor frieght... grainger nothing ove $50 $75max for your purposes get a yellow wiggy also for raw votage testing and ohm ring outs...HD LOWES HF check it out http://www.harborfreight.com/ac-dc-d...ter-37772.html
Old 10-12-2011, 05:46 PM   #4
JJboy's Avatar
Fieldpiece sc77
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-12-2011, 05:47 PM   #5
biggles's Avatar
an industry standard with HVAC guys in NYC takes a beating drops rain being stepped on.gives raw voltage 115V,220V,480V with continuity indication to ring stuff out bulbs,switches,motors.hang it on a hook in that shop and nobody touches it except the king.... http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Old 10-12-2011, 05:50 PM   #6
I use fieldpiece. The 56,76 and 77 are all good meters that will last a home owner a lifetime and they're reasonably priced.
Old 10-12-2011, 05:58 PM   #7
biggles's Avatar
know what is wierd after 20yrs of using old reliable meter it dies and you wish you have bought 2 of them
Old 10-12-2011, 08:26 PM   #8
I heard that
Master of Cold is offline   Reply With Quote
Old 10-12-2011, 08:29 PM   #9
For the money, a real nice meter is the Pheonix Gold meter by UEI. It will do everything, including ac/dc volts, capacitance, and has an amp clamp. Its usually about $70 -$90 online. You can get the upgraded model and take temperatures for a little more.
Old 10-12-2011, 08:30 PM   #10
Buying fieldpiece meters around here should come with complimentary vasoline....
Old 10-13-2011, 12:22 AM   #11
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by JJboy View Post
Fieldpiece sc77
you got that right although it's around $180. the sc76 (no backlight but all other features as sc77) is about $20 less.
Op, you can get the mini workhorse, Fieldpiece sc 46 or 48 ( they have a few models in this particular meter) that does just about everything the sc77 does but it's palm size and thus under $100. I'm certain you'll go hunting for things to use it on once you have it, probably change careers just to be able to use it on a daily basis.
The sc77
and the mini version. It even has a dual display, reads amps and voltage at the same time.
NEVER EVER EVER EVER EVER EVER BUY A CHEAP METER!!!
Doc Holliday is offline   Reply With Quote
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 09:26 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
water meter relocation or fix? jinglwang Plumbing 3 05-26-2009 10:15 PM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 07:35 AM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
