HVAC Mastic And Covering With Paint - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 04:57 PM   #1
HVAC Mastic and Covering with Paint
Hello,
I plan to apply water based air duct sealant to the seams on the inside of several sheet metal ceiling boxes
Interested to know if anybody has experience painting over air duct sealant with latex paint? The objective is to paint the inside of the ceiling boxes black since they can be seen through the grilles. (coating the outside of the boxes with sealant is not an option).
Since the boxes are made of galvanized sheet metal, I would like to prime with a latex acrylic galvanized metal primer (rustoleum) and then cover with black latex paint (rustoleum).
Thanks is advance for any help and advice.
mattorrell is offline   Reply With Quote
Old 07-29-2013, 06:12 PM   #2
An old Tradesmen
Rewards Points: 6,476
That will work fine.
Epoxy paint over black mastic over concrete in basement kidnitro6 Flooring 0 03-21-2012 03:50 PM
Can you apply New Mastic over Old? section319 Flooring 4 02-19-2012 11:19 AM
Painting over roof mastic librayacht Painting 1 12-04-2010 12:53 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
