Old 12-19-2011, 04:19 PM   #1
Limited Experience
HVAC Low Voltage Wire
What wire size is standard for the 24V side of things?
raleighthings is offline   Reply With Quote
Old 12-19-2011, 04:24 PM   #2
I'm Your Huckleberry
http://americanhvacparts.com/Merchan...&Store_Code=AM
even if you only have four wires connected at the stat, buy five wire. having one extra wire is always good.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-19-2011, 04:30 PM   #3
[quote=raleighthings;797728]What wire size is standard for the 24V side of things?[/quo
the answer to your question is 18 gauge
harleyrider is offline   Reply With Quote
Old 12-19-2011, 04:32 PM   #4
yep 18 guage 5-conductor
Old 12-19-2011, 04:45 PM   #5
as seen on tv
18 ga if it is not to far
qbert is offline   Reply With Quote
Old 12-19-2011, 06:22 PM   #6
Limited Experience
OK. Now please define "far".
Old 12-19-2011, 06:56 PM   #7
standard house......no worries............now if you live in a 400 room mansion.....different story
Old 12-19-2011, 07:09 PM   #8
Limited Experience
Yes. V=IR
Old 12-19-2011, 07:41 PM   #9
Originally Posted by raleighthings View Post
Yes. V=IR
if that's the equation for voltage (ohm's law) it's E, not V.
there's a thing called amperage drop when it comes to electricity. the further the wire the more drop. why too far is important but I've never had an effect concerning stat wire. I have had issues with 100' extension cords and vacuum pumps and electric saws. They simply wouldn't turn on, I had to use my 50' cord.
Thanks.
Old 12-19-2011, 08:03 PM   #10
Limited Experience
When did it change? When studying EE it was V. And i for current in one class then i for square root of -1 in next. Then j for that in next.
Anyway V=IR gives you the voltage drop once you calculate the resistance of the wire. Which for HVAC use under 50 ft is usually treated a 0 ohms and thus 0 volts drop. It's more of a rounding error in this case.
Old 12-19-2011, 08:09 PM   #11
I actually think it can be either. In school the instructor used E but on wikipedia it's (still) V.
Thanks.
Old 12-19-2011, 08:15 PM   #12
In my Refrigeration and Air Conditioning Technology book, newest version aka The Bible, it's E.
Thanks.
Old 12-19-2011, 08:25 PM   #13
Thanks.
Old 12-19-2011, 09:08 PM   #14
Thanks.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Low voltage wire & electrical wire (NM) dyang Electrical 3 05-04-2010 11:02 PM
Dogs chewed my low voltage wire smithlive HVAC 8 06-25-2009 02:44 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 09:03 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
