HVAC Lines, Cost To Replace? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 08:28 AM   #1
Trucon01's Avatar
Rewards Points: 510
HVAC lines, cost to replace?
Hi All,
Attached is a picture of the 3 wires leading to the compressor outside to the furnace. It looks like they are pretty beat up from being tightened to hard. Since my ceiling is open, I was thinking about having them replaced. It might be about 20-25 feet from the compressor to the furnace. What are some rough estimates?
Trucon01 is offline   Reply With Quote
Old 02-12-2012, 08:52 AM   #2
could not tell u from just that one pic.
don't know the suction line size. don't know how it's hooked up inside or out side.
more pics are in order.
hvac5646 is offline   Reply With Quote
Old 02-12-2012, 08:54 AM   #3
Trucon01's Avatar
Rewards Points: 510
Sure thing. Tell me exactly what you want to see and I'll go do it right now. Thanks for your time.
Old 02-12-2012, 08:55 AM   #4
Rewards Points: 13,450
I do not see any wires. Copper pipe, another pipe wraped in insulation and some beat up duct tape is all I see.
Old 02-12-2012, 09:06 AM   #5
Trucon01's Avatar
Rewards Points: 510
There is another brown line, with a bunch of little wires inside. They look like the wires inside Cat5 sheathing.
Old 02-12-2012, 09:10 AM   #6
Experienced
Jackofall1's Avatar
$125 for service call
$250 for material
$300 for labor
$125 for freon evacuation and reinstall.
Call it a nice round $800 bucks, or you could call a local service company and have them out to give you a real quote.....your choice.
Mark
Old 02-12-2012, 09:13 AM   #7
biggles's Avatar
pull the bell(brown)wire wrap away from that suction/LL run is that what you talking about..whats that silver/gray stuff is there oil residue there?
Old 02-12-2012, 09:24 AM   #8
Trucon01's Avatar
Rewards Points: 510
On the left side is duct tape and on the right side is a metal clamp that was way over tightened and digging into the line.
Old 02-12-2012, 09:27 AM   #9
biggles's Avatar
there is no vibration there did the clamp cut into the copper or just the insulation
Old 02-12-2012, 09:35 AM   #10
Trucon01's Avatar
Rewards Points: 510
I believe just the insulation. But I figured since there are other spots where this happened and I am demoing the entire basement, I might as well have all new lines run.
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
Reasonable cost to replace mailbox and light post? akphs Off Topic 1 04-26-2010 09:55 PM
Hvac question on R410A lines zootjeff HVAC 6 06-21-2009 08:25 PM
Cost to replace entry and screen doors?? kiss44 Carpentry 6 01-30-2009 09:46 AM
