HVAC lines, cost to replace?
1 Attachment(s)
Hi All,
Attached is a picture of the 3 wires leading to the compressor outside to the furnace. It looks like they are pretty beat up from being tightened to hard. Since my ceiling is open, I was thinking about having them replaced. It might be about 20-25 feet from the compressor to the furnace. What are some rough estimates? |
could not tell u from just that one pic.
don't know the suction line size. don't know how it's hooked up inside or out side. more pics are in order. |
Sure thing. Tell me exactly what you want to see and I'll go do it right now. Thanks for your time.
I do not see any wires. Copper pipe, another pipe wraped in insulation and some beat up duct tape is all I see.
There is another brown line, with a bunch of little wires inside. They look like the wires inside Cat5 sheathing.
$125 for service call
$250 for material $300 for labor $125 for freon evacuation and reinstall. Call it a nice round $800 bucks, or you could call a local service company and have them out to give you a real quote.....your choice. Mark |
pull the bell(brown)wire wrap away from that suction/LL run is that what you talking about..whats that silver/gray stuff is there oil residue there?
On the left side is duct tape and on the right side is a metal clamp that was way over tightened and digging into the line.
there is no vibration there did the clamp cut into the copper or just the insulation
I believe just the insulation. But I figured since there are other spots where this happened and I am demoing the entire basement, I might as well have all new lines run.
| All times are GMT -4. The time now is 11:15 PM. |
