HVAC Lennox G61MVP - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 11:36 AM   #1
HVAC Lennox G61MVP
My new furnace takes a significantly long time, 4 hrs, to raise 12 degrees. It is a dual stage and I feel that the second stage is not kicking in. The dip switches are all set in the factory position. My house is not huge and the furnace was sized correctly. I am wondering if there are other dip switches that should be moved to increase the efficeincy of my new furnace
JLEIF is offline   Reply With Quote
Old 12-31-2011, 12:05 PM   #2
Factory setting is for a two stage thermostat so if you have a single stage stat it only calls for low fire. I believe that's dip switch #1, check the manual to be sure.
Old 12-31-2011, 12:31 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
take the lower door off and see if there is a wire attached to the W2 terminal. if not then the dip switch needs to be changed so the board sees a 1 stage tstat or call the installer back and have him do it.
Old 12-31-2011, 01:52 PM   #4
BEFORE YOU DO ANYTHING......how new is new? working on this unit while its still in the first year warranty could void your over all warranty..........if its less then 1 year old, call the installing contractor back out....this should be a free call.
harleyrider is offline   Reply With Quote
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
