HVAC Leaking... Not Condensate Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 05:55 PM   #1
HVAC Leaking... not condensate pump
Hi,
My HVAC is leaking water. I believe it's coming from plenum, down past the blower unit to the floor. I have checked the condensate pump, and it's working... however, it seems very possible that the PVC going into the condensate pump is clogged.
I have shop vac'd it, but didn't fix it because the PVC is a Y shape with one branch going to the unit in the attic and the other to the unit in the basement. Vacuuming the end of the Y that goes to the pump probably just grabbed air from the upstairs unit since the downstairs seems clogged. (See picture)
Questions:
- How do I get access to the plenum area to see if the PVC is clogged or something else is the problem? It seems to be a large sheet metal box without any access panels. (See picture)
- Is there a better idea than vacuuming it out to remove the clog if that's it?
Thanks,
Dan
HVAC Leaking... not condensate pump-y-shaped-pvc1.jpg   HVAC Leaking... not condensate pump-pipesintoplenum1.jpg
danrckville is offline   Reply With Quote
Old 06-20-2012, 06:09 PM   #2
Cut the pvc pipe and glue a coupling back in when done.
The Following 2 Users Say Thank You to Marty S. For This Useful Post:
danrckville (06-20-2012), Evstarr (06-21-2012)
Old 06-20-2012, 06:23 PM   #3
Thanks Marty! I was afraid of that... if I do it, any downside to putting in some ball valves so I can shutoff one end or the other to avoid cutting the PVC again when I need to vacuum out one side or the other?
Old 06-20-2012, 06:28 PM   #4
JJboy's Avatar
You can add a PVC T just after p-trap for inspection and clean.....I don't see the second drain port....but you can install a safe T-switch....... if overflow the t-switch will shut off the unit..... no more water everywhere.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-20-2012, 09:04 PM   #5
Thanks for the idea... I didn't know the Safe T type switch existed for inline with pipes... nice idea. I cut the pipe tonight and just created two separate runs (one for the upstairs and one for the downstairs) so I could easily just vacuum each out without any issues.
We'll see how it goes tomorrow when it gets hot again.
Thanks for the advice everyone!
Old 06-21-2012, 08:20 AM   #6
HVAC Tech/Owner
Rewards Points: 604
It looks like from the picture that another AC's drain ties into a lower AC"s Drain? If it does...then a clog near the condensate pump will backup to the lower ac unit.... They should be seperate drains for each AC.
Technow is offline   Reply With Quote
Old 06-21-2012, 10:14 AM   #7
Rewards Points: 340
you can easily work the horizontal and vertical run with a drain clog remover. i'd try that before cutting into anything.
NitroNate is offline   Reply With Quote
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
How to connect condensate pump DCJH Plumbing 0 01-12-2010 02:35 PM
Condensate Pump confusion GlennAndrew HVAC 9 01-01-2010 05:25 PM
Good furnace condensate pump? Tommy2 HVAC 11 12-12-2008 04:31 PM
1997 carrier hvac with heat pump pdominoexpress HVAC 5 01-17-2008 10:46 PM
