HVAC Just Serviced...thoughts On Needed Repairs - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-27-2009, 08:03 PM   #46
An old Tradesmen
Rewards Points: 6,074
Your probably only gong to get a 1 year part warranty from them.
Capacitors(what they are calling phase shifters).
Are referenced by their uF/mfd rating first, and voltage second.
So you would want to two 5x370volt capacitors.
And one 35+3x370(look at voltage rating on current oneto confirm voltage first)volt capacitor.
You can get capacitors at Grainger. They may have to order the 35+3x 370 volt.
Yuri. Your being robbed if you pay more then 8 bucks wholesale. for two 7x370 caps.
Old 05-27-2009, 08:40 PM   #47
Yuri is a Canadian. Everything is more expensive there. i know of a Canadian mfg who is in Windsor. They come to Graingers In Troy to buy industrial supplies.
Even with the tariff they paid on the supplies they were still less expensive to buy here.
hvaclover is offline   Reply With Quote
Old 05-27-2009, 09:28 PM   #48
An old Tradesmen
I keep forgetting that.
Old 05-27-2009, 10:11 PM   #49
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
He probably needs a 35 x 5 not 35 x 3 capacitor. Actually we pay about $8 for the capacitors but I was allowing for some markup for Graingers. Plus we have better beer so I think I will stay put. LOL
Old 05-27-2009, 10:17 PM   #50
Keep the old caps and have them checked independently or you can check them with a 9v batt., a one megohm resistor from Radio Shack and a DVM.
Old 05-27-2009, 10:34 PM   #51
HVAC / Plumbing
Hope I can say this on the AIR,,,,I don't know what you guys charge. I replaced 2 caps..last week at the same house (2 different units).. Charged $210.00 including trip charge
kenmac is offline   Reply With Quote
Old 05-27-2009, 11:03 PM   #52
That is a 35X3 MFD. ICP uses them
Old 05-27-2009, 11:52 PM   #53
An old Tradesmen
I'm $65 diagnostic, and $137 for the dual run cap.
Second dual run would be $51.
Old 05-28-2009, 06:29 AM   #54
To bad no one is closer I would just have one of you come out and do the replacements....
ashton is offline   Reply With Quote
Old 05-28-2009, 06:41 AM   #55
An old Tradesmen
Sorry too.
My flat rate progressively comes down in price, the more things I'm doing on the service call.
And if the repairs/PM part replacements are approved for change out during the PM check, then there is of course no diagnostic charge. And all parts are at a lower price. Since I'm already there.
It sounds like the company your using, has one tier only. And charges for each part as if its the only thing wrong.
Old 05-28-2009, 11:20 AM   #56
Well I ordered the caps...i just have a quick question. On the new caps will it have markings for the common, herm, fan? This may be a stupid question I just dont want to screw it up
Old 05-28-2009, 12:02 PM   #57
An old Tradesmen
Yes.
It will be marked.
Old 05-28-2009, 12:14 PM   #58
Home Air Direct's Avatar
Yes, I just called and caps are marked as noted.
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Weird HVAC configuration need your thoughts Rikky HVAC 2 09-10-2007 04:11 PM
Thoughts on Cheap Flooring Idea Needed! MissyM Flooring 4 09-01-2007 08:51 PM
