HVAC Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 06:38 PM   #1
HVAC issue
Hi, I am new to this forum and new to homeowning. I just bought an older home last week in fact. My HVAC issue is that the air/heat vent in my sons room won't blow and it's FREEZING in there. All other vents blow and it's fine. What can I do without calling a repair tech-I don't have the money right now to pay for repairs.
Thanks for any help!
Heather
Hkarp79 is offline   Reply With Quote
Old 02-04-2011, 06:39 PM   #2
Rewards Points: 6,652
Go look for a damper shut, or something shoved into the vent from the bedroom keeping air from flowing into it.
Old 02-04-2011, 06:57 PM   #3
Thanks! Theres no damper thingie-it's an old vent the circular ones that look like bullseyes. I tried to take it off but the previous owner painted over it and its kinda stuck to the ceiling. But I did use a flashlight and saw that there was nothing blocking the duct.
Old 02-04-2011, 10:54 PM   #4
Rewards Points: 492
From the basement, if ductwork is exposed, try to find a duct branch that could go to that bedroom. If you see any that have been disconnected, that's the problem. If it's an A/C or heat system from the attic, then that's where to start. It may even have fallen off and you're heating your attic.
With no louver adjustment, previous room occupant may have decided they like it colder and disconnected on purpose but probably never closed the door.
diyorpay is offline   Reply With Quote
Old 02-05-2011, 08:51 AM   #5
Rewards Points: 5,336
If you don't want to get a repair person, you'll need to do more then look at it with a flashlight. You have 2 choices, get more hands on or call someone who knows what they're doing.
Where is this duct running? In the attic? Between floors?
If it's in the attic, go up there and find the duct. Maybe it's disconnected. Maybe the damper is closed. Maybe the duct was removed.
Find and trace the duct. There's probably a main duct in the attic and branches to each of the rooms.
Access to the attic could be in a closet.
Ron
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 07:18 AM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
plumbing copper for HVAC refrigerant lines? Mike in Arkansas HVAC 9 03-21-2010 09:52 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
altering HVAC flow levels? joeyboy HVAC 7 05-01-2008 05:22 PM
