HVAC Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 02:35 AM   #1
HVAC Insulation
Can you use ""Zip Tight Seals" or " Dutc Strap" to tight refelctive insulation around hot air hard pipes for the furnace?
Also, how would you secure the dutc strap? Would you drive screw in the pipes, then use alumin tape over it ..or is a bad idea.
avtck is offline   Reply With Quote
Old 01-10-2010, 07:54 AM   #2
Rewards Points: 292
Are you using Reflectix or something similar?
Their directions call for overlapping seams and (approx) 3" metal tape to seal the seams.
Are you using an air space?
veesubotee is offline   Reply With Quote
Old 01-10-2010, 07:25 PM   #3
It is a reflective with fiberglass insulation on the inside and alumin foil on the outside. Not sure 100%, but there is a print with WCL.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
HVAC ducting and foam insulation seadrift HVAC 1 08-17-2009 01:11 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
