-   -   HVAC install from last year, Help with Chimney, lost closets (http://www.diychatroom.com/f17/hvac-install-last-year-help-chimney-lost-closets-120418/)
coderguy 10-17-2011 08:15 PM
Hello,
Some of you may have read about our HVAC install from last winter. We did a complete tear out and better planned duct work.
Anyways, we were forced to give up our first floor closet (bedroom) and second floor closet (bathroom). It wasn't done well, and I'm considering bringing in a second HVAC company to improve the duct work yet again; but I wanted to run the idea by here, especially since I will be doing the framing/etc before redoing the bed/bath.
The duct work runs to the attic from the basement, supply and return. They run parallel to the chimney. I have tried to re-layout these rooms to have closets; as they need them. With no luck.
So my idea is to remove the chimney. It is only used by the hot water heater; which I could direct vent outside??? The supply and return could then be moved over to the chimney's location?
I'm hoping to get some feedback on the possibility and any pitfall warnings. I would have the chimney removal, roofing and duct work done professionally. I would then be able to resume my bed/bath projects.
Any help is appreciated!!
coderguy 10-29-2011 01:29 PM
Bump.
Any input on this?
raylo32 10-29-2011 02:20 PM
Does the water heater use a type B vent? That might be problematic venting out the side. The pros here could tell you if that is even possible in code. Also would need thimbles to keep the vent the required minimum distance from combustibles.
ben's plumbing 10-29-2011 07:39 PM
here in pa you can not vent a draft hood appliance to the side wall of a dwelling it is not legal or to code, If you are going to remove chimney then I would install a power vented heater that vents out side wall with pvc pipe which passes code...
coderguy 10-30-2011 12:06 AM
What if I switched over to a tankless water heater?
hvac benny 10-30-2011 12:26 AM
With tankless you'll most likely have to up-size your gas line, maybe even your whole gas system and meter. There are power vented water heaters like ben's plumbing said, and there are also water heaters that are just like regular water heaters, but instead of power venters, they use a concentric vent that can go out the side wall, just like a fireplace. I've installed a few, but I don't recall who made them. A little googling may turn something up if I don't remember the name.
Edit: found a link to the manual: http://www.bradfordwhite.com/images/...als/45839C.pdf
