-   -   HVAC help please (http://www.diychatroom.com/f17/hvac-help-please-33225/)
shumv 12-05-2008 06:27 PM
HVAC help please
I'm having a problem with my HVAC. I own a condo and there's no heat. The heating unit is in the wall with the filter just below it. The fan keeps coming on and blowing room temperature air. I checked the fuse panel and it's fine. I adjusted the temperature on the thermostat to see if that will get it to work. No luck. I opened up the panel and see a motor like module with copper pipes going into it. The pipes are hot. Can anyone help?
hvaclover 12-05-2008 06:36 PM
Is your water heater in the same closet?
shumv 12-05-2008 06:41 PM
No, it's a newer condo. I believe it's a centralized boiler. There's no boiler in my unit. But the copper pipes leading into the module is hot. I can take a pic and post it, if that helps?
yuri 12-05-2008 06:59 PM
The picture will help. Do you rent the condo? If so the building maintenance guy should be involved.
shumv 12-05-2008 07:15 PM
3 Attachment(s)
Here are the pics. I own the condo. It's the weekend and it's hard to get a HVAC professional right now. Was wondering if I can fix it myself for the weekend. If not, then I'll call the HVAC professional on Monday. Thanks for your help guys.
Attachment 6384
Attachment 6385
Attachment 6386
hvaclover 12-05-2008 07:18 PM
It's a fan coil.
All the condos serviced by one boiler and a chiller.
If the fan does not work switch the thermostat fan auto-on to the on position and see if it comes on
shumv 12-05-2008 07:20 PM
Originally Posted by hvaclover (Post 194428)
It's a fan coil.
The fan is working. It's just blowing out room temp air.
yuri 12-05-2008 07:21 PM
Appears to have electric solenoid valve(s) on the water line which may not be opening. The thermostat may not be sending a signal or a relay may not be opening the solenoid valve. You may need a Pro to sort it out. If you rent and damage it they may hold you liable.
shumv 12-05-2008 07:23 PM
Can I try hitting it to get it to work? Or will that break it even more? What kind of heating system is this called?
SKIP4661 12-05-2008 07:26 PM
If you can hold on to the water pipes the boiler is probably not up to temp. Check with the neighbors to see if there is a problem with theirs.
hvaclover 12-05-2008 07:26 PM
LOL... when all else fails....SMACK IT!
No, but you should call you bldg. maint man. You do have one do you not?
shumv 12-05-2008 07:30 PM
Hahaha. Yeah I do have one. He checked and said the water is not getting into the module. He said call a professional.
shumv 12-05-2008 07:31 PM
The neighbour have heat. The water pipes are pretty hot. I can't hold it.
hvaclover 12-05-2008 07:36 PM
then try the valve. Dont beat on it. Just give a firm tap.
A lot of the water valves these days are coming from China and they jam.
shumv 12-05-2008 07:52 PM
You guys are awesome! There's heat coming out. I think it was clogged. I took a hammer and lighty taped the water valves. There's a hot spot along the pipes, then there's a warm spot, then there's a cold spot. I just tapped around the warm area where I think is clogged and turned it back on. Heat is coming out of the vents now. Thanks guys!
