HVAC Help. Fuse Blowing - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2015, 07:30 AM   #1
Rewards Points: 14
HVAC Help. Fuse blowing
I have a fridgidaire FG6RC 080c-16B gas furnace and had it installed about 8 years ago. Last winter it shut off on me and I opened the panel and noticed the little 3 am fuse on the board was blown. I had someone come out and look at it. They diagnosed it as a bad themostat and connected a new one. About a month ago the same thing happened. I looked at the board and there was a bad 5amp fuse in the spot that says....Max fuse amp 3. So the guy must have put a 5 amp fuse in and its still blowing them. Any help would be greatly appreciated.
raymond_anthony is offline   Reply With Quote
Old 12-08-2015, 09:04 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
check all your thermostat wiring inside the furnace and from the furnace to the thermostat for bare spots or damage. Had a cat chew thru one once. Rodents too.
Old 12-08-2015, 09:33 AM   #3
Rewards Points: 14
I just notice the green wire towards the sheathing is exposed. I'm not how this got this way (probably when originally stripped). However, these shouldn't be touching the panel so I don't think this tripped it.
Fuse keeps blowing in xmas lights Mstrlucky74 Electrical 16 12-03-2015 08:13 PM
Rhem Heat Pump low voltage fuse keeps blowing z4racer HVAC 3 02-29-2012 07:02 PM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 04:22 PM
Outdoor Christmas Lights Fuse Keeps Blowing mhp8982 Electrical 6 11-18-2011 10:10 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
