HVAC - Heating My Attic Space - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 02:30 PM   #1
HVAC - Heating my Attic Space
Remodeling an attic space in a Cape Cod home. The added space is approx 800 sqft. I currently have forced hot air in the main house, but running the ducts to second floor is not an option. Also, the current furnace won't support the added space. I was thinking electric baseboard and opening the door from first flloor. I am planning on insulating well, but trying to determine my best options for heating. Electric heat is expensive.
Vermont1 is offline   Reply With Quote
Old 01-31-2009, 02:33 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
Do you need air conditioning up there as well? There are minisplit units that work as heat pumps as well. Expensive but require no ductwork and are ideal for retrofits/single areas. For info only, don't know this guy.
http://www.minisplitsystems.com/
Old 01-31-2009, 03:01 PM   #3
I was planning on using a window unit for my a/c needs, although I am open to suggestions.
Old 01-31-2009, 03:35 PM   #4
Are you sure it won't support the space?
Did you do a heat loss calc?
We have a Cape that is 1250 1st floor, maybe 800 2nd floor
Only 1 radiator on the 2nds floor in a small bedroom
But the furnace is actually oversized based on a heat loss calc
I'm not planning on adding any hot water heat upstairs
There won't be a door, so cold air will flow down the stairs
I will add electric radiant floor heat in the new steam/shower bathroom. Since these are bedrooms I don't need a lot of heat up there. AT present with the existing door closed it stays about 45 without sheetrock & missing some insulation
I built a 14k AC into one wall & have 3 venting skylights
Old 01-31-2009, 05:10 PM   #5
My heating guy said the furnace won't support, but I still won't be able to run the ducts. I too don't need a lot of heat since it will be used primarily for a master bedroom. Just want to see options outside using baseboard.
Old 01-31-2009, 07:41 PM   #6
Hvac Pro
yuri's Avatar
Pro's and Cons:
Window units can be noisy, I wouldn't want one in my bedroom.
Electric baseboard heat is simple and never breaks down.
Mini splits are good but they may need expensive repairs in the future.Initial cost is high.
Old 01-31-2009, 10:08 PM   #7
My heat guy said the same thing about my furnace
Turns out my furnace is almost 2x the size needed for my house & will heat my entire addition - almost 2x the space
Did he run a Manual J Calc?
Do you know what model you have, someone here may be able to confirm approx sizing
Old 02-01-2009, 08:46 AM   #8
Thanks for the replies. Scuba Dave, I really didn't persue because running the ducts is not a viable option. Thanks
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 01:47 PM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 07:19 AM
Heating an attic cibula11 HVAC 13 02-01-2007 11:50 AM
HVAC for 650 sq ft attic Mercenary HVAC 1 06-10-2006 08:16 AM
